joemar
Level 4
Level 4
This script is designed to make it easy to locate a blade which requires maintenance.  Once you specify the chassis and blade the script turns on ALL the locator LEDs on the chassis' blades and the chassis itself.  The user then taps the chassis locator LED button and the script turns off all the lights except the server that needs maintenance.  The script then prompts the user to acknowledge when maintenance is complete and turns off the blade LED.
Change Log:
     v0.1.01 - Initially posted version
