08-18-2016 08:29 AM - edited 03-01-2019 12:51 PM
I noticed in the 2.2.8a b-series bundle that the MK81 VIC firmware version is 2.2.3b (ucs-m81kr-vic.2.2.3b.bin), I assume this is correct.
The blade I am upgrading is a B200-M2.
Solved! Go to Solution.
08-18-2016 08:47 AM
Yes, that is correct.
You could use this "new" hardware and software matrix tool to verify the same
https://ucshcltool.cloudapps.cisco.com/public/#
PS: Something to keep in mind is M81KR is supported until ESXi 5.1 U3, ESXi 5.5 and above runs out of support (You can verify the same in the above link by selecting the appropriate versions)
-Majid
08-18-2016 08:47 AM
-Majid
