711
Highlighted
Beginner
m81KR cNA adapter with vsphere 5.5
is the m81KR cna adaptre not compatible with esxi 5.5? I look at the compatibility matrix and did not mention anthing about this card on esxi 5.5
for firmware 2.2(1)
any idea?
4 REPLIES 4
Highlighted
Tony,
Typically this might also depend on server you're running.
The interoperability tool is pretty accurate and you can always confirm with:
http://www.cisco.com/c/dam/en/us/td/docs/unified_computing/ucs/interoperability/matrix/r_hcl_B_rel2-21.pdf
and
http://www.cisco.com/web/techdoc/ucs/interoperability/matrix/matrix.html
Looks like from CNA only M73KR -E and -Q are supported ( plus VM-FEX and VICs).
M.
Highlighted
Hi all,
With UCSM at 2.2 based release, you can still have your server & adapter firmware at 2.1.3 with B200M2 and M81KR running ESXi5.5 and ESXi5.5U1.
This has been already tested and shown in the interop matrix
This is a supported combination
Karthic
Highlighted
Beginner
hi
I am running b200m2 wih the m81kr card
I am stuck with this hardware but I need to upgrade to esxi 5.5
It looks like its not suppported but just wanted to see if anyone is running this configuration.
esxi 5.5 on b200m2 with M81KR
Highlighted
Beginner
I'm running vmware 5.5 with firmware 2.2(1c) and a M81KR NIC.  Booting is with local storage, so I can't confirm if this will work with features like boot from SAN.
Content for Community-Ad
