10-25-2011 08:16 AM - edited 03-01-2019 10:07 AM
I am pretty sure the answer is no, but is there a way to expand the MAC-Address Pools or any of the pools through the UCS MGR ?
If not why is that not an option ?
Solved! Go to Solution.
10-25-2011 08:22 AM
The answer is YES, you can always add a block of mac addresses to the current pool which will provide you more mac addresses to use.
Hope this helps!
./Abhinav
10-25-2011 08:22 AM
Hope this helps!
./Abhinav
10-25-2011 08:30 AM
Your right. I totally forgot about the fact that you can create a new block without having to create a new pool.
Thank you
