03-16-2015 02:05 AM - edited 03-01-2019 12:04 PM
Hello Team,
We have several UC deployments based on UCS C220 M3 servers (the famous BE6K).
I'm not coming from systems background, I'm rather a Voice guy.
In fact, the BE6K UCS C220 M3 is shipped by default with only one Power Supply.
However, in the CIMC, we find many times that an alert is raised for Power Supply redundancy and the system LED turns to solid Amber.
Here's the alert : PSU_REDUNDANCY: PS Redundancy sensor, Redundancy Lost was asserted
We don't understand why this alert is raised when we already know that the BE6K server only contains one PSU ?
Is this a true problem or a false alarm ?
How can we clear this alert ?
In fact the fact the system LED is Amber is not a good sign from the customer perspective. As well as when we let it stay in the Amber LED state we wouldn't that a bigger problem (and a true one) may happen ?
The CIMC version is : 1.5.4f
Please advise.
Solved! Go to Solution.
03-16-2015 05:46 AM
Unfortunately not (that I am aware of) but if you go to Faults on the Server tab, you should be able to see a summary of alerts and check what is going on.
If this is helpful, please rate... if it answers your question, please mark it as so for future users.
-Kenny
03-16-2015 05:32 AM
The server supports 2 PSUs, by having only one that alert is expected... Place a second PSU on that server and checked if there are further issues that require investigation.
-Kenny
03-16-2015 05:40 AM
Thank you for your input Keny.
In fact we don't have a second PSU since it isn't shipped with the server. So, in our case (BE6K server) it's clearly a false alarm.
Is there a way to acknowledge/delete/ignore the alert, so that we don't get confused with other more important alerts that may truly affect the platform ?
Thank you again.
03-16-2015 05:46 AM
-Kenny
