Doug Barnes
Beginner
MDS Code Level for UCS FC Port Channel/Trunking
What is the required MDS code level needed to support FC Port-Channeling/Trunking on a 9222i, 9148, or 9509/9513 w/ Gen2 line cards to UCS 1.4(3)?
I know the fport-channel-trunk feature is needed and was released in MDS 4.2 code but I have seen documents that this level of code wont support these features when used to connect to Cisco UCS.
Can someone confirm?  Is NXOS 5.0(4) or higher required?
7 REPLIES 7
mipetrin
Hi Doug,
Have a read through the following document, which details the requirements, configuration and verification steps to setting this feature up:
https://supportforums.cisco.com/docs/DOC-14838
In short, you are required to utilize NXOS 5.0(4)
Hope that helps.
Michael
Michael,
Yes, I have read through the document you reference.
The author mentions MDS 5.0(4) or higher code level specifically.  I was just writing for confirmation.
I have been unsuccessful in finding any mention of requiring 5.0(4), outside of this doc, in UCS Release Notes, MDS Release Notes, BUG Scrubs, web searches, etc.
I had hoped if it was indeed a requirement it would have shown up in more places.
Thank you for your assistance.
Doug
Hi Doug,
For UCS manager 1.4(3) , configuring f-port-channel/trunk with MDS version 4.2(5) is enough.
Just 2 weeks ago i did for my clients and it has been working fine.
ram
David McFarland
Doug,
I wrote the doc almost a year ago and it doesn't have the latest interop matrix support information. The current MDS NX-OS support is located in this doc: http://www.cisco.com/en/US/docs/switches/datacenter/mds9000/interoperability/matrix/intmatrx.html
While, I wish this was also duplicated in UCS docs, they are more or less taking the stance that 3rd party (Cisco MDS is this case) interop is maintained by the 3rd party. EMC, Netapp, or even Cisco.
It would be a nightmare updating UCS docs with 3rd party qualifications and support.
The short answer to your question is:
UCS 1.4(1), 1.4(2), 1.4(3) Is supported by MDS9000: 3.3(4a), 3.3(5), 4.2(1a), 4.2(1b), 4.2(3a), 4.2(5), 5.0(1a), 5.0(4), 5.0(4c)
NPV was introduced in MDS 3.3. f port-channel/trunk was introduced in MDS 4.2.
As Ram mentioned above, 4.2(5) is what I would recommend if I wanted to implement f port-channel and/or f port-trunk. I have also had recent experience with 4.2(5) and it worked great with a large UCS f port-channel/trunk implementation
The specific switch limitations I mentioned in my doc still exist. Only certain models of MDS will support f port-trunk. Almost all models will support f port-channel.
Dave
David McFarland
Doug,
Sorry, I forgot to add, all of your MDS models listed  9222i, 9148, or 9509/9513 w/ Gen2, will fully support f port-channel and f port-trunk.
Dave
kshama_ism
Beginner
Is this issue resolved, i have same problem with CISCO 9148 with UCS  6248UP. all the  UCS Fabrics  updated with latest code..
indvidual FC uplinks works fine, but as soon  apply the port channel configuration it fails with error.
MDS is running  with 5.0(1a)   model : DS-C9148-16P-K9
We have UCS 6248 (2.04b) and MDS 9148 (5.2.8) and have fport-channel-trunk working. We also have UCS 6120 (2.04b) and MDS 9222i (5.2.6a) working as well.   We are only doing f-port portchannel and not vsan trunking.... which means only 1 vsan is enabled on this F-port port channel.
We enabled "feature fport-channel-trunk" on the MDS and then built the port channel on both the MDS (cli) and UCS (gui).
In order for it to come up we had to disable on both sides and then re-enable the port channel.
interface port-channel 10
  channel mode active
  switchport rate-mode dedicated
  switchport trunk mode off
Kris
Content for Community-Ad
