MDS configuration for port channel
simon.geary
I've tried to set up the new FC port channel upload to a pair of MDS 9124s, but as I don't know enough about the MDS side I can't get the link to come up. Are there any references available anywhere that tell you blow by blow exactly how to configure the MDS side of the port channel? Or perhaps a sample working config?
I don't think it is possible to configure the Fabric Interconnects in FC switch mode as only NPV is supported on those. The only switch mode that is supported and possible to configure is the Ethernet LAN switching mode.
I configured this last week on a pair of MDS 9124s and had to to enable the F port trunking and channeling protocol feature using this command
"feature fport-channel-trunk"
After that I was to get SAN Port Channeling working. Here is a snipit of my configuration:
feature npiv
interface port-channel 11
  channel mode active
  switchport rate-mode dedicated
interface fc1/1
  port-license acquire
  channel-group 11 force
  no shutdown
interface fc1/2
  no shutdown
13 Replies 13
Robert Burns
There's a bit of MDS config required.  Please reference:
http://www.cisco.com/en/US/docs/switches/datacenter/mds9000/sw/5_0/configuration/guides/int/nxos/pc.html
Essentially you have to
1. Put the member ports in the appropriate VSAN
2. Ensure the member ports are set to the appropriate mode (Fx usually)
3. Create the Port Channel interface
4. Add the first member
5. Add second member
6. No shut the port channel interface.
Let me whip this up in my lab quick and I'll provide exact steps/config example.
Robert
David McFarland
Simon,
A few items:
1) You are on 1.4.1i Balboa code
2) FI's are in FC switch mode as MDS 9124's don't support F-port channel (NPV/NPIV)
3) It's a lot easier the first time if you have matched speed sfp+ all around. Although, with the correct configs, unmatched speeds can be made to work.
If the FIs are in switch mode and your MDS is running a minimum 3.3 here are some configs that may help:
MDS side interfaces 4/11 and 4/12 are plugged into the UCS fc ports. First setup and ensure ISLs are working properly between UCS and MDS, then configure the port-channels
interface fc4/11
  switchport mode E
  switchport trunk mode auto
  no shutdown
interface fc4/12
  switchport mode E
  no shutdown
The UCS GUI Equipment -> Fabric Interconnects -> FI-A -> Set FC Switching Mode. This will cause both FI's to reboot into FC switch mode. This is VERY DISRUPTIVE, both FI's will reboot.
On the UCS CLI you should see this on the UCS fc ports connected to the MDS
cae-sj-ca3-A(nxos)# show running-config interface fc 2/1-2
!Command: show running-config interface fc2/1-2
!Time: Wed Oct 20 16:49:39 2010
version 4.2(1)N1(1.4)
interface fc2/1
  switchport mode E
  no shutdown
interface fc2/2
  switchport mode E
  no shutdown
Until you have VSAN trunks enabled, make sure the ports on the UCS and MDS are in the same VSAN. VSAN 1 for example.
Once you have working ISLs, then proceed to turn them into port-channels and enable VSAN trunking. Start with the MDS
Create a channel group, it should look like this
cae-sj-9506-1# show run interface port-channel 3
!Command: show running-config interface port-channel 3
!Time: Wed Oct 20 17:06:01 2010
version 5.0(1a)
  channel mode active
  switchport mode E
  switchport trunk mode auto  <-- VSAN trunking
Enable VSAN trunking on the MDS ISL interfaces, it'll look like this:
cae-sj-9506-1# show run interface fc 4/11-12
!Command: show running-config interface fc4/11-12
!Time: Wed Oct 20 17:07:05 2010
version 5.0(1a)
interface fc4/11
  switchport mode E
  no shutdown
interface fc4/12
  switchport mode E
  no shutdown
Add the channel group information to the MDS ISL interfaces:
Enter configuration commands, one per line.  End with CNTL/Z.
cae-sj-9506-1(config)# interface fc 4/11-12
cae-sj-9506-1(config-if)# channel-group 3 force
fc4/11 fc4/12 added to port-channel 3 and disabled
please do the same operation on the switch at the other end of the port-channel,
then do "no shutdown" at both ends to bring it up
cae-sj-9506-1(config-if)# show run interface fc 4/11-12
!Time: Wed Oct 20 17:07:39 2010
version 5.0(1a)
interface fc4/11
  switchport mode E
  no shutdown
interface fc4/12
  switchport mode E
  no shutdown
Create the SAN port channel on the UCS side
SAN -> SAN Cloud -> Fabric A -> FC Port Channels -> Create Port Channel
After you create the SAN port channel in UCS, make sure and enable it. I also bounce the MDS port channel at this point.
If all is correct, in a few agonizing minutes, the port-channel will be formed and passing data.
cae-sj-ca3-A(nxos)# show interface san-port-channel 1
san-port-channel 1 is trunking
    Hardware is Fibre Channel
    Port WWN is 24:01:00:0d:ec:d3:5d:c0
    Admin port mode is E, trunk mode is on
    snmp link state traps are enabled
    Port mode is TE
    Port vsan is 1
    Speed is 8 Gbps
    Trunk vsans (admin allowed and active) (1,10,26,50,66,100-101,103,123,222,24
0)
    Trunk vsans (up)                       (1,10,50,100,103)
    Trunk vsans (isolated)                 (26,66,101,123,222,240)
    Trunk vsans (initializing)             ()
    5 minute input rate 2312 bits/sec, 289 bytes/sec, 2 frames/sec
    5 minute output rate 1440 bits/sec, 180 bytes/sec, 2 frames/sec
      2669 frames input, 194760 bytes
        0 discards, 0 errors
        0 CRC,  0 unknown class
        0 too long, 0 too short
      2677 frames output, 158316 bytes
      0 input OLS, 1 LRR, 0 NOS, 0 loop inits
Again, make sure you have the ISLs up an running first before configuring the port-channels. It makes troubleshooting much easier.
Let me know if you need any help.
feature npiv
  channel mode active
interface fc1/1
  no shutdown
interface fc1/2
  no shutdown
@Jeremey
As of Balboa (1.4) there is FC Switch mode & FC End Host mode - in addition to Ethernet Switch mode & Ethernet End Host mode.
Robert
Oh, I didn't realize that Robert. Thank you for correcting me. I guess that is for direct attach FC storage configurtions?
Exactly right - the FC switch mode runs the bare minimum required to directly attach NetApp/EMC targets directly to the FI's.
Let me know when you've had a chance to play around with 1.4 and/or direct attach storage - would love to hear your feedback.
Robert
feature npiv
  channel mode active
interface fc1/1
  no shutdown
interface fc1/2
  no shutdown
Jeremy,
Would this setup be the same on the MDS 9148 switches?
The MDS 9148 supports f-port channel running NX-OS 4.2.7a. You can use Rob Burns' config example for f-port channel with UCS in default End-Host-Mode (NPV) or the config I provided if you want to run in switch mode. The 9148 will support both configurations. Be warned, depending on the sfp speeds, you will have to out-of-service ports in the port group when running multiple ports at dedicated rate mode of 8GB or 4GB in the same port group.
Thanks Jeremy, feature fport-channel-trunk did it for me and I have the port channels working now on MDS 9124 running 5.0.4.
As a side note to all this, it looks like a compatibility matrix for FC switches is required for UCS. Prior to 1.4, it seems that all you needed to know about your FC switch was that it supported NPIV. The new 1.4 features mix this up a little and it is no longer easy to understand what FC switch supports what new feature. A blog post for someone perhaps!!
Thanks to everyone who chipped in with help.
Good point Simon.  We're just polishing up some Whitepapers that should shed some practical light on the new FC features of 1.4.
Stay tuned.
Robert
In my lab I'm using 9222i's so I can use FC End Host mode with my UCS.  FYI - I'm not using FC trunking, just FC Port channel.
Here's how I have set my system up.
6100-A Ports fc2/7, fc2/8
MDS-A Ports fc1/7, fc1/8
UCS GUI Side
1. From equipment tab add each interface (fc2/7, fc2/8) to the appropriate VSAN 2000
2. From the SAN tab, under Fab-A, create Port Channel 200, added both ports fc2/7, fc2/8 as members
(Port Channel will be disabled).
3. Enable all members ports and the parente port channel
MDS CLI Side
1. Add member ports to appropriate VSAN 200
  mds9222i(config)# vsan database
  mds9222i(config-vsan-db)# vsan 2000 interface fc1/13-14
2. Set Ports to correct mode - fabric ports
  mds9222i(config)# int fc1/13-14
  mds9222i(config-if)# switchport mode f
3. Create & configure the Port Channel
  mds9222i(config)# int port-channel 200
  mds9222i(config-if)# switchport mode F
  mds9222i(config-if)# channel mode active
  mds9222i(config-if)# vsan database
4.  Add FC members to Port Channel
  mds9222i(config-if)# channel-group 200 force
5. Unshut the Port Channel
   mds9222i(config)# int po200
   mds9222i(config-if)# no shut
The relevant config from the UCS (NXOS show run) and the MDS are below:
UCS Side
interface san-port-channel 200
  channel mode active
  switchport mode NP
  no shutdown
  interface fc2/7
  no shutdown
interface fc2/8
  no shutdown
MDS Side
  interface port-channel 200
  channel mode active
  switchport mode F
  switchport rate-mode shared
  no shutdown
interface fc1/13
  switchport mode F
  no shutdown
interface fc1/14
  switchport mode F
  no shutdown
You can verify if everything is working correctly with:
show int brief (ensure both member ports are showing up)
show int port-channel x (ensure Port channel is up and configured correctly)
show port-channel summary (should show two member ports)
Robert
On our lab 9124s we have NX-OS 5 and the only way I could get the port channels to come up was to enable the "fport-channel-trunk" feature. My 6120s are in the default End-host mode.
@Jeremy,
Hi, I'm the customer that the OP is working with on this configuration.
I have a 9124 running NXOS 4.1.3a. I can see the  "fport-channel-trunk" feature and it is disabled.
I dont need F port trunking, just the channeling. It seems from the difference between our configs is that all I need to do is enable that feature to be able to configure the F port trunk. With the feature disabled I get 'port disabled', 'incompatible port types' etc.
So, questions:
1 - will it work with 4.1.3a? This 9124 is the only switch in the fabric right now so upgrading would be service affecting. The commands appear to be there, I just get the errors. I will upgrade when I can build some redundancy into the solution.
2 - is enabling the  "fport-channel-trunk" feature disruptive (see 1 above)?
3 - with the feature disabled, do you see the errors I describe above?
FC and MDS config is a grey area for me so I do appreciate any input...!
thanks a million
iain
