02-26-2014 03:42 AM - edited 03-01-2019 11:33 AM
I am getting the memory dump error and server ( UCS C250 M1 ) is getting down. After reboot working for couple of days and again getting the same error and down.
Please find the below screenshot and help me to resolve the issue.
02-26-2014 05:28 AM
May want to consult vmware, the psod backtrace looks like the following vmware bug:
02-26-2014 10:45 PM
Hi Brain,
Thanks for the immediate responce. Let me try the workaround and update you.
02-28-2014 04:07 PM
It looks like you need to upgrade your network drivers based on the PSOD backtrace.
You can check this link:
http://www.cisco.com/web/techdoc/ucs/interoperability/matrix/matrix.html
03-14-2014 02:39 AM
Hi zvega,
Thanks for replay,
I am using C250-M1 with Esxi5.1, which I couldn't find in given link.
Need you help on this.
