11-07-2015 11:20 AM - edited 03-01-2019 12:27 PM
What is the best way to migrate servers currently on HP chassis equpment to a brand new Cisco UCS chassis? Is there for instance a a HP tool to migrate over to a boot lun? Then we can boot the same servers up on Cisco UCS?
Or do we have to reinstall all the servers and restore backups in a maintenance window?
Solved! Go to Solution.
11-13-2015 01:26 PM
physical server = e.g. ESXi ? you have to install this in your UCS blades ? same would apply for Windows and/or Linux ? I don't see any other solution ?
11-08-2015 11:13 AM
Hi Atle
Don't know which OS you have ? OS installed on local disks ?
Lets assume this is a VMware ESXi installation (Hyper-V would work essentially very similar).
You would setup UCS domain; connect to the common network and storage.
Then you would install ESXi on the local disk of boot over SAN ? then add this ESXi host in vCenter to the cluster, having nodes on the HP C7000 and UCS; then you could vmotion VM's to the new platform.
We have done many such migrations in a nondisruptive fashion.
Walter.
11-12-2015 02:29 PM
yes, we can do that for VMs. But what about physical servers?
11-13-2015 01:26 PM
11-16-2015 02:03 PM
I was looking to see if therewas a online migration tool , lik eEMC Host Migration Enabler, between HP and EMC storage.
11-14-2015 05:40 PM
beyond what Walter Dey said ... take a look at this link: Data Center Case Study: How Cisco IT Migrates Critical Applications from HP Superdome to Unified Computing System.
Hope this helps
