08-05-2017 11:21 PM - edited 03-01-2019 01:16 PM
hello,
can anyone recommend how i can to monitoring UCS system?
hardware monitoring level like, fans, etc...
Thanks..
Solved! Go to Solution.
08-06-2017 04:22 AM
Greetings.
See https://communities.cisco.com/docs/DOC-37197
Also on https://www.cisco.com/c/en/us/td/docs/unified_computing/ucs/sw/mib/b-series/b_UCS_MIBRef/b_UCS_MIBRef_chapter_0100.html note:
Statistics Type | MIB that Gathers the Statistic | Statistics Table Name in SNMP |
Ethernet |
CISCO-UNIFIED-COMPUTING-ETHER-MIB .1.3.6.1.4.1.9.9.719.1.16 is the parent OID where the key statistics reside. |
etherPauseStats—Packet paused etherLossStats—Packet loss etherErrStats—Packet errors etherTxStats—Packets transmitted etherRxStats—Packets received |
Adapter |
CISCO-UNIFIED-COMPUTING-ADAPTOR-MIB .1.3.6.1.4.1.9.9.719.1.3 is the parent OID where the key statistics reside. |
adaptorEthPortBySizeLargeStats adaptorEthPortBySizeSmallStats adaptorEthPortStats adaptorEthPortOutsizedStats adaptorEthPortMcastStats |
Fiber channel |
CISCO-UNIFIED-COMPUTING-FC-MIB .1.3.6.1.4.1.9.9.719.1.20 is the parent OID where the key statistics reside. |
fcStatsTable fcErrStatsTable |
Blade and rack level |
CISCO-UNIFIED-COMPUTING-COMPUTE-MIB .1.3.6.1.4.1.9.9.719.1.9 is the parent OID where the key statistics reside. |
computeMbPowerStats—Provides all motherboard power statistics for every blade. computeMbTempStats—Provides all motherboard temperature statistics for every blade. |
Rack level |
Processor |
CISCO-UNIFIED-COMPUTING-PROCESSOR-MIB .1.3.6.1.4.1.9.9.719.1.41 is the parent OID where the key statistics reside. |
processorEnvStats—Provides all CPU power and temperature statistics for every CPU socket. |
Equipment |
CISCO-UNIFIED-COMPUTING-EQUIPMENT-MIB .1.3.6.1.4.1.9.9.719.1.15 is the parent OID where the key statistics reside. |
equipmentFanStats—Provides all statistics for every physical fan in every chassis in a UCS domain. equipmentFanModuleStats—Provides all fan module temperature statistics for every fan module in every chasis in a UCS domain. equipmentChassisStats—Provides all chassis level temperature statistics for every chassis in a UCS domain. equipmentPsuStats—Provides all chassis level power and temperature statistics for every power supply in a UCS domain. equipmentIOCardStats—Provides all chassis level power and temperature statistics for every fabric extender in a UCS domain. |
Memory statistics |
CISCO-UNIFIED-COMPUTING-MEMORY-MIB .1.3.6.1.4.1.9.9.719.1.30 is the parent OID where the key statistics reside. |
memoryUnitEnvStats—Provides all memory DIMM temperature statistics for every memory module. |
Switching statistics |
CISCO-UNIFIED-COMPUTING-SW-MIB .1.3.6.1.4.1.9.9.719.1.46 is the parent OID where the key statistics reside. |
sysEnvStats—Provides all fabric interconnect level power statistics for every fabric interconnect in a UCS domain. |
Kirk...
08-06-2017 11:36 PM
Hi Lior
https://de.slideshare.net/Ciscodatacenter/ucs-central-best-practices-for-single-and-multi-ucs-domain-management?next_slideshow=1
and
https://communities.cisco.com/community/technology/datacenter/compute-and-storage/ucs_management/blog
gives a good overview what's available.
08-06-2017 04:22 AM
Greetings.
Ethernet |
Adapter |
Fiber channel |
Rack level |
Processor |
Equipment |
Memory statistics |
Kirk...
08-06-2017 06:55 AM
hello,
thanks, i mean to Cisco software for monitoring....
08-06-2017 12:58 PM
You want to configure callhome to send e-mail alerts for certain errors and events.
Smart Call Home Quick Start Configuration Guide
You setup the UCS to forward e-mails to your SMTP server and you can indicate individual or e-mail alias in the profiles.
08-06-2017 11:36 PM
Hi Lior
and
