MS Win 2k8 and B200-M2 Blade Support
pjwhitby_2
Hi All,
I am getting conflicting answers on supportability. We are running the following hardware
B200-M2 blades with M71KR-E CNAs running firmware package 1.4(3i)
and according to the recently released UCS Hardware and Software Interoperability Utility at http://www.cisco.com/web/techdoc/ucs/interoperability/matrix/matrix.html
the use of MS Windows Server 2008 R2 x64 SP1 is not supported unless we upgrade to v2.0(1)
yet according to the Hardware and Software Interoperability Matrix at http://www.cisco.com/en/US/docs/unified_computing/ucs/interoperability/matrix/r_hcl_B_rel1_43.pdf
the use of MS Windows Server 2008 R2 x64 SP1 is supported?
which is correct?
2 Accepted Solutions
abbharga
Level 4
Level 4
Go by the hardware and the software matrix.
I have checked the combination that you mentioned and it is supported.
./Abhinav
mishield
The conflicting answer was caused by a bug in the new interoperability utility.  It has now been corrected.
abbharga
Level 4
Level 4
./Abhinav
Thanks, I thought as much ;-)
mishield
Thanks, much appreciated
