08-10-2012 04:19 AM - edited 03-01-2019 10:33 AM
I have four B250 M2 in one 5108, only one 6140 FI , uplink is a 3750G-24ts switch , All B250 install vmware Esxi5, have one redhat vm on each B250, i have a software use 234.0.100.32 multicast address communication each other , I enable multicast routing on 3750g , I can see multicast group on 3750G , but my software working very unstable. if i mirge all redhat vm on one b250 , the software work fine . how can i solve it ?
08-10-2012 04:53 AM
on the 3750 you can configure an igp querier so the multicast entries won't time out after 3 minutes
08-10-2012 05:27 AM
Thanks very much !
I use ip multicast-routing on 3750 already,
HXUCS-A(nxos)# show ip igmp snooping groups
Type: S - Static, D - Dynamic, R - Router port
Vlan Group Address Ver Type Port list
294 */* - R Eth1/5
294 234.0.100.32 v2 D Veth735 Veth759 Veth747
Veth741
HXUCS-A(nxos)# show ip igmp snooping mrouter
G - G-pinned, Q - Query accepting interface
Vlan Router-port Type Uptime Expires
294 Eth1/5 D 01:32:31 00:04:49
HXUCS-A(nxos)# show ip igmp snooping querier
Vlan IP Address Version Expires Port
294 194.196.58.50 v2 00:04:16 Ethernet1/5
Multicast routing work unstable , my application work unstable too
HXUCS-A(nxos)# show ip igmp snooping event-history vlan
vlan Events for IGMP Snoop process
2012 Aug 10 12:25:17.319751 igmp [4899]: : igmp_cl_output_l2: Before IP api ...
2012 Aug 10 12:25:17.319749 igmp [4899]: : igmp_cl_output_l2: ...
2012 Aug 10 12:25:17.319717 igmp [4899]: : Received MRD Update: router-port: Eth
1/5
2012 Aug 10 12:25:17.319711 igmp [4899]: : Received MRD from Ethernet1/5 source
on intf 1c17.d349.a4c7 with mac 547f.ee50.d0cc
2012 Aug 10 12:24:47.869135 igmp [4899]: : igmp_cl_output_l2: Before IP api ...
2012 Aug 10 12:24:47.869132 igmp [4899]: : igmp_cl_output_l2: ...
2012 Aug 10 12:24:47.869092 igmp [4899]: : Received MRD Update: router-port: Eth
1/5
2012 Aug 10 12:24:47.869087 igmp [4899]: : Received MRD from Ethernet1/5 source
2012 Aug 10 12:24:47.115447 igmp [4899]: : Suppressing report for (*,234.0.100.3
2) came on Vethernet747
2012 Aug 10 12:24:47.115439 igmp [4899]: : Updated oif Vethernet747 for (*, 234.
0.100.32) entry
2012 Aug 10 12:24:47.115429 igmp [4899]: : Received v2 report: group 234.0.100.3
2 from 194.196.58.32 on Vethernet747
2012 Aug 10 12:24:47.115412 igmp [4899]: : Process a valid IGMP packet
2012 Aug 10 12:24:46.518649 igmp [4899]: : Received v2 report: group 224.0.1.40
