12-05-2018 03:06 AM
we are looking for ENIC and FNIC drivers for RHEL7.5
Host Firmware 3.2(3)
Server Type: B-Series
Server Model: Cisco UCS B200 M3
Processor Name: Intel Xeon E5-2600 v2 Series processors
Operating System: Red Hat
Operating System Version: Red Hat Enterprise Linux 7.5
As per UCS Hardware and Software Compatibility the FNIC driver version is 1.6.0.34, but we are not able to find it in ISO.
Thanks in advance.
Solved! Go to Solution.
12-05-2018 04:35 PM - edited 12-05-2018 04:36 PM
Greetings.
If you check the 4.01c driver ISO for linux, there is a 1.6.0.44 FNIC listed for RHEL 7.5
The ENIC version is 2.3.0.45
It's a little confusing because, unlike the Firmware bundles themselves, the Driver ISO versions are only very loosely tied to firmware releases. You will want to check the driver contents list, to confirm which driver ISO has the specific driver version you need.
Kirk...
Greetings.
Kirk...
