Field Notice 70545
1964
Amit Vyas
Beginner
New Chassis with 2204XP IOM & B200 M3 Servers
We are going to install 2 more additional chassis in existing setup, below is the list of existing setup and new chassis details
Existing Setup Details:
2 x 6120XP Fabric Interconnect with 2.0(1t) firmware
2 x 5108 Chassis with 2 x 2201XP IOM and 8 x B200 M2 servers per chassis
New Chassis Details:
2 x 5108 Chassis with 2 x 2204XP IOM and 8 x B200 M3 servers per chassis
Just wanted to know that is there any issue / problem if we install different configuration IOM and Blade servers in existing setup? If answer is yes then why? And if answer is no then too why? Just want to understand how the things works if answer is no
-Amit
1 REPLY 1
mwronkow
Hello Amit,
B200 M3 servers require a minimum UCS version of 2.0(2).  Please upgrade prior to installing the new blades.
No problem mixing the newer & older IOMs on the same FI as they fully backwards compatible.  Since the FIs are the 6100 model, the 2204 will not form port-channels on the fabric ports (IOM to FI).  A 6200 would be required for that functionality.
The webinar given in February covers the hardware & software configuration differences for the new FIs, IOMs, mezz adapters.
https://supportforums.cisco.com/community/netpro/data-center/unified-computing?view=video
Matthew
Create
Recognize Your Peers
Content for Community-Ad
