01-08-2014 10:20 AM - edited 03-01-2019 11:26 AM
I have two VSM's (vm's) running in HA pair on two blade servers in same HP chassis. In the beginning I was running the 1000v environment using the Eval licensing but now I have installed the Cisco provided license files.
My question is this: When I invoke the command "show license usage NEXUS1000V_LAN_SERVICES_PKG" I see the 6 installed Licenses, however, I also see that the "Installed Licenses in Use equals 0. Should I see Installed Licenses in Use equal 2?
vdivc01-n1kv# show license usage NEXUS1000V_LAN_SERVICES_PKG
Feature Usage Info
Installed Licenses : 6
Default Eval Licenses : 0
Max Overdraft Licenses : 16
Installed Licenses in Use : 0
Overdraft Licenses in Use : 0
Default Eval Lic in Use : 0
Default Eval days left : 0
Licenses Available : 22
Shortest Expiry : Never
vdivc01-n1kv# show mod vem license-info
Licenses are Sticky
Mod Socket Count License Usage Count License Version License Status
3 2 - - licensed
4 2 - - licensed
vdivc01-n1kv# sho license brie
N1KVFEAT201312300740270040.lic
N1KVFEAT201312300741200540.lic
N1KVFEAT201312300742010570.lic
N1KVFEAT201312300742330820.lic
N1KVFEAT201312300743060900.lic
N1KVFEAT201312300743430650.lic
Any help is very appreciated!
David
Solved! Go to Solution.
01-08-2014 11:29 AM
The installed licenses are used for Advanced Edition. I suspect your switch is still in Essential Edition mode since there isn't a Count or License Version for those modules. Check output of sh switch edition.
Example:
SV2# sh switch edition
Switch Edition: Advanced <------
Advanced Features
Feature Name Feature State
cts disabled
dhcp-snooping disabled
vxlan-gateway enabled
Licenses Available: 22
Licenses In Use: 10 <---------------
License Expiry Date:
01-08-2014 11:29 AM
Example:
Advanced Features
cts disabled
01-08-2014 11:43 AM
That is exactly what it was.
I switched it from Essential to Advanced and now I see exactly what I was expecting to see.
Feature Usage Info
Installed Licenses in Use : 4
Licenses Available : 18
Application
VEM 3 - Socket 1
VEM 3 - Socket 2
VEM 4 - Socket 1
VEM 4 - Socket 2
Thank you Matthew for the help!
