01-26-2012 03:34 AM - edited 03-01-2019 10:15 AM
I have deployed two 1010 appliances, the upstream switches are two 6509 wihtout VSS.
I cannot get the HA up.
Output of show module is:
Mod Ports Module-Type Model Status
1 0 Nexus 1010 (Virtual Services App Nexus1010 active *
2 0 Virtual Supervisor Module powered-up
Mod Sw Hw
1 4.2(1)SP1(3) 0.0
Mod MAC-Address(es) Serial-Num
1 00-19-07-6c-5a-a8 to 00-19-07-6c-62-a8 NA
Mod Server-IP Server-UUID Server-Name
1 10.146.102.10 NA NA
________________________________________________________________________________________
Output of show system redundancy status is :
Redundancy role
administrative: primary
operational: primary
Redundancy mode
administrative: HA
operational: None
This supervisor (sup-1)
Redundancy state: Active
Supervisor state: Active
Internal state: Active with warm standby
Other supervisor (sup-2)
Redundancy state: Standby
Error in getting supervisor and internal state of other supervisor.
___________________________________________________________________________________________________________________
and the output of show system internal redundancy info is:
My CP:
slot: 0
domain: 25
role: primary
status: RDN_ST_AC
state: RDN_DRV_ST_AC_SB
intr: enabled
power_off_reqs: 0
reset_reqs: 9
Other CP:
slot: 1
status: RDN_ST_SB
active: true
ver_rcvd: true
degraded_mode: true
Redun Device 0:
pdev: f37e8640
alarm: true
mac: ff:ff:ff:ff:ff:ff
tx_set_ver_req_pkts: 319
tx_set_ver_rsp_pkts: 0
tx_heartbeat_req_pkts: 61193
tx_heartbeat_rsp_pkts: 0
rx_set_ver_req_pkts: 0
rx_set_ver_rsp_pkts: 0
rx_heartbeat_req_pkts: 0
rx_heartbeat_rsp_pkts: 0
rx_drops_wrong_domain: 0
rx_drops_wrong_slot: 0
rx_drops_short_pkt: 0
rx_drops_queue_full: 0
rx_drops_inactive_cp: 0
rx_drops_bad_src: 0
rx_drops_not_ready: 0
rx_drops_wrong_ver: 0
rx_unknown_pkts: 0
Redun Device 1:
pdev: f37e8240
alarm: false
mac: 00:02:3d:70:19:81
tx_set_ver_req_pkts: 314
rx_set_ver_rsp_pkts: 5
rx_heartbeat_rsp_pkts: 61165
rx_drops_bad_src: 0
rx_unknown_pkts: 0
Can anyone please help in resolving this issue.
Sabih
01-26-2012 03:35 AM
I have implemented Uplink type 2 and for the time being just connected first two ports only, I have not connected any data links i.e. eth 3 to eth 6 are not connected.
01-26-2012 09:17 PM
Hi Sabih,
For a Nexus 1010 pair to form HA redundancy, the communicate with each other via the Control VLAN. You would have specified this during your installation.
Can you verify that they are both utilizing the same Control VLAN.
n1010# show svs domain
Furthermore, ensure that this vlan is defined and forwarding, on the relevant ports, on the upstream 6509s.
Michael
