No link between IOM port 2/2/3 and fabric interconnect B
Hello
I am trying to remove an uplink from an IOM to the fabric interconnect as its not required.  I have tried to reset the I/O module and re-acknowledge the chassis with no luck, it is still shown in the GUI with the error message as in the subject.  We are currently running 2.0(1s).  The kit isn't in production yet.
Thanks for any help
abbharga
Level 4
Level 4
Hi barry,
The only way for you to clean that up will be to de-comission the chassis in question and re-add it back.
Thanks!
./Abhinav
abbharga
Level 4
Level 4
Hi barry,
Thanks!
./Abhinav
Excellent, thanks for that.  It seems a pretty heavy handed approach to clean that up.  If that config was left, would it cause issues...apart from the error message?
Thanks again
Yes i agress thats a pretty heavy approach to clean it. No if you left it there as it is, there would have been no operational issues. It would have just left this fault in the UCSM.
./Abhinav
