10-30-2013 11:54 AM - edited 03-01-2019 11:19 AM
I am getting the following error message when trying to configure a vPC from a set of 6248 FIs to a set of N5Ks. Lacp and vpc are enabled on the 5ks.
"No operational members"
sho vpc br
Legend:
(*) - local vPC is down, forwarding via vPC peer-link
vPC domain id : 1
Peer status : peer adjacency formed ok
vPC keep-alive status : peer is alive
Configuration consistency status : success
Per-vlan consistency status : success
Type-2 consistency status : success
vPC role : secondary
Number of vPCs configured : 1
Peer Gateway : Disabled
Dual-active excluded VLANs : -
Graceful Consistency Check : Enabled
Auto-recovery status : Enabled (timeout = 240 seconds)
sho vpc consistency-parameters int po 22
Legend:
Type 1 : vPC will be suspended in case of mismatch
Name Type Local Value Peer Value
Shut Lan 1 No No
STP Port Type 1 Default Default
STP Port Guard 1 None None
STP MST Simulate PVST 1 Default Default
mode 1 on on
Speed 1 10 Gb/s 10 Gb/s
Duplex 1 full full
Port Mode 1 trunk trunk
Native Vlan 1 1 1
MTU 1 1500 1500
Admin port mode 1
vPC card type 1 Empty Empty
Allowed VLANs - 1-4094 1,xxx.xxx.xxx.xxx.xxx.xxx
sho int po 22 br
Port-channel VLAN Type Mode Status Reason Speed Protocol
Interface
Po22 1 eth trunk up none a-10G(D) none
feat(config-if)#
sho run int po 22 membership
!Command: show running-config interface port-channel22 membership
!Time: Mon Sep 28 18:31:06 2009
version 6.0(2)N2(2)
switchport mode trunk
speed 10000
vpc 22
interface Ethernet1/15
channel-group 22
interface Ethernet1/16
channel-group 22
Solved! Go to Solution.
11-02-2013 02:15 PM
Terry,
I had the same error when starting to integrate UCS with the Nexus product line. In addition to LACP, how many vPC's do you have on "each" 5K? From the diagrams above, you should have 2. I bet you have only 1.
Mike
10-30-2013 12:11 PM
N5Ks = 6.0(2)N1(2)
UCS = 2.1(3a)
10-30-2013 12:13 PM
Just to confirm, you're connecting like this:
FI-A Port X_____PoX______N5K1
FI-A Port Y N5K2
FI-B Port X_____PoY______N5K1
FI-B Port Y N5K2
Ensure the same VLANs are allowed on each N5K for each VPC. From your output above they dont look consistent.
Confirm your topology with as much detail as you can so we can assist further.
**Also ensure on your N5K side you're using "channel-group X mode active" to ensure LACP is enabled. We only support active Port Channels with UCS.
Robert
10-30-2013 12:16 PM
FI-A Port 17_____Po22______N5K1
FI-A Port 18 N5K2
FI-B Port 17_____Po22_____N5K1
FI-B Port 18 N5K2
Checking vlans now.....
10-30-2013 12:24 PM
10-31-2013 04:56 AM
Here are the commands, I might have missed something...
xxxx(config)# int e1/15-16
xxxx(config-if-range)# channel-group 22
xxxx(config-if-range)# int po 22
xxxx(config-if)# vpc 22
10-31-2013 05:12 AM
That creates a static port channel (mode on) vs. active (mode active aka LACP).
Change your Port channel mode to "mode active" on the N5K sides as detailed above.
Robert
11-01-2013 07:44 AM
Almost there.... So the port channel is up on FI-A and still getting no operational members on FI-B.
11-02-2013 02:15 PM
Terry,
Mike
