02-21-2013 06:03 PM - edited 03-01-2019 10:53 AM
Cisco requirements state "FC ports should end on last port of the module".. I would assume that means last port of ANY module and not the last ports of the "last module"?
Just confirming when installing a "n55-m16up" (16 port expansion module) into a NX 5548UP which already has FC ports assinged in E1/31 and E1/32 you DONT need to relocate the FC ports to the last ports of the expansion module?
Cheers,
Solved! Go to Solution.
03-07-2013 08:12 PM
Yes that's right. It is last port of any module. In short, this requirement is per module. So when you are putting in new module, you don't need to move your existing fc ports from module 1
03-07-2013 08:12 PM
