One breakout cable in UCS 6332 discovery multi 5108 chassis?
Jeahowan Kim
Hello
We are going to migration UCS 6248 to 6332 .
But the question of composition came up.
UCS 6332's 40G single port can be divided into 4x10G ports by using breakout cable and
can be configured as port-channel in each IO Module 2204xp(Chasis 1, Chassis2),
and can be configured to discovery multi chassis?
Is it possible to configure it as shown in the attached cofigure below?
Kirk J
Greetings.
What you are proposing should work fine.
Generally, you can just think of the cabling/compatibility as you would with regular 10Gb ports.
As long as your are using compatible 10Gb SFPs you should not have any issues.
Kirk...
