02-11-2013 11:31 AM - edited 03-01-2019 10:52 AM
on my 1000v, when i try to move my control nic to the 1000v dvS, packets are not forwarding and the vem loses connectivity to the vsm.
on the 1000v my uplink is configured as
port-profile type ethernet ucs-n1kv-uplink
vmware port-group
switchport mode trunk
mtu 9000
switchport trunk allowed vlan 1-3967,4048-4093
channel-group auto mode on mac-pinning
no shutdown
system vlan 50,60,220
state enabled
on the L3control port profile I have
port-profile type vethernet ucs-n1kv-L3control-vlan60
capability l3control
vmware port-group
switchport mode access
switchport access vlan 60
no shutdown
system vlan 60
state enabled
ON the UCS side, both nics are configured as trunks and it does includes vlan 60.
any idea why it does not forward on the 1k dvs? ut works just fine on the standard vswitch. all the nics are configured as trunks
02-11-2013 11:36 AM
Is it possible VLAN 60 is configured as the Native VLAN on your UCS vNICs? Check the vNIC allowed VLANs (including Native) on the vSwitch uplinks and the DVS uplink - compare the two from a UCS perspective - are they identical?
Likely a native VLAN issue...
Send a screen shot of the vSwitch view from vCenter when the VSM's control NIC is currenlty connected. I want to see the VLAN tag on the Port Group.
Robert
02-11-2013 12:09 PM
Robert, on the UCS side, native vlan is actaully vlan 50. not 60.
this is the vswitch, the control nic is tagged with vlan 60. On the ucs side, native vlan is 50.
on the same server, vmnic0,1 are on standard switch, set as trunk ports and native vlan 50. It does include vlan 60
on the same server, vmnic4,5 are on the 1k dvs, set as trunk ports (no native vlan set). it does include vlan 60
02-11-2013 12:11 PM
Can we get a "show svs domain"???
02-11-2013 12:13 PM
vsm-n1kv# sh svs domain
SVS domain config:
Domain id: 1000
Control vlan: NA
Packet vlan: NA
L2/L3 Control mode: L3
L3 control interface: control0
Status: Config push to VC successful.
Control type multicast: No
02-11-2013 12:18 PM
vsm-n1kv# show module
Mod Ports Module-Type Model Status
1 0 Virtual Supervisor Module Nexus1000V active *
2 0 Virtual Supervisor Module Nexus1000V ha-standby
3 248 Virtual Ethernet Module NA ok
4 248 Virtual Ethernet Module NA ok
Mod Sw Hw
1 4.2(1)SV2(1.1a) 0.0
2 4.2(1)SV2(1.1a) 0.0
3 4.2(1)SV2(1.1a) VMware ESXi 5.1.0 Releasebuild-914609 (3.1)
4 4.2(1)SV2(1.1a) VMware ESXi 5.1.0 Releasebuild-914609 (3.1)
Mod MAC-Address(es) Serial-Num
1 00-19-07-6c-5a-a8 to 00-19-07-6c-62-a8 NA
2 00-19-07-6c-5a-a8 to 00-19-07-6c-62-a8 NA
3 02-00-0c-00-03-00 to 02-00-0c-00-03-80 NA
4 02-00-0c-00-04-00 to 02-00-0c-00-04-80 NA
Mod Server-IP Server-UUID Server-Name
1 10.220.220.230 NA NA
2 10.220.220.230 NA NA
3 10.50.2.30 c6456f3e-2aa1-11e2-1100-00000000002f xxxxxxxxxxxxxxx
4 10.50.2.31 c6456f3e-2aa1-11e2-1100-00000000000e xxxxxxxxxxxxxxx
vem communicates with vsm fine on vswitch. once moved to dvs on the 1k I get
vsm-n1kv#
vsm-n1kv# 2013 Feb 11 20:16:42 vsm-n1kv %VEM_MGR-2-VEM_MGR_REMOVE_NO_HB: Removing VEM 3 (heartbeats lost)
2013 Feb 11 20:16:42 vsm-n1kv %VEM_MGR-2-VEM_MGR_REMOVE_NO_HB: Removing VEM 4 (heartbeats lost)
2013 Feb 11 20:16:48 vsm-n1kv %SYSMGR-2-SYNC_FAILURE_MSG_PAYLOAD: vdc 1: Failure from active SUP
2013 Feb 11 20:16:48 vsm-n1kv %KERN-2-SYSTEM_MSG: mts_tcp_send_sync_msg():225 max retry count reached when trying to send msg to standby, (-11) - kernel
2013 Feb 11 20:16:48 vsm-n1kv %KERN-2-SYSTEM_MSG: do_xmit_mtsbuf_sync_msg_tcp(): Sync TCP send failed with error -70 - kernel
2013 Feb 11 20:16:48 vsm-n1kv %KERN-2-SYSTEM_MSG: do_mts_standby_sync: failed to sync message, ha_stage 1, opc 1813, error -70 - kernel
2013 Feb 11 20:16:48 vsm-n1kv %KERN-2-SYSTEM_MSG: node=4 sap=1 desc=MTS Sync Thread, rq=1248 lq=0 pq=0 nq=1 sq=0 buf_in_transit=0, bytes_in_transit=0 - kernel
2013 Feb 11 20:16:53 vsm-n1kv %SYSMGR-2-SYNC_FAILURE_STANDBY_RESET: Failure in syncing messages to standby for vdc 1 causing standby to reset.
2013 Feb 11 20:17:01 vsm-n1kv %PLATFORM-2-MOD_REMOVE: Module 2 removed (Serial number T5056B45E2E)
2013 Feb 11 20:17:01 vsm-n1kv %VEM_MGR-2-MOD_OFFLINE: Module 3 is offline
2013 Feb 11 20:17:01 vsm-n1kv %VEM_MGR-2-MOD_OFFLINE: Module 4 is offline
vsm-n1kv# 2013 Feb 11 20:17:35 vsm-n1kv %PLATFORM-2-MOD_DETECT: Module 2 detected (Serial number :unavailable) Module-Type Virtual Supervisor Module Model :unavailable
02-11-2013 12:22 PM
here is the screenshot on the dvs after I moved the control over to the 1kol nic over
02-11-2013 01:21 PM
Tony,
While the VSMs are showing blocked, can you go to the Console of the ESX host where the primary VSM resides, and get the output of:
vemcmd show trunk
Also from the VSM can you get "show int veth x" where x is the VSM's Control interface. If you're not sure what vEth # it is, use "show int virtual" to get the vEth mapping.
Robert
02-11-2013 04:13 PM
~ # vemcmd show trunk
Trunk port 16 native_vlan 1 CBL 1
vlan(1) cbl 1, vlan(3972) cbl 1, vlan(3970) cbl 1, vlan(3969) cbl 1, vlan(3968) cbl 1, vlan(3971) cbl 1, vlan(50) cbl 1, vlan(60) cbl 1, vlan(220) cbl 1, vlan(10) cbl 1,
Trunk port 21 native_vlan 1 CBL 1
vlan(1) cbl 1, vlan(50) cbl 1, vlan(60) cbl 1, vlan(220) cbl 1, vlan(10) cbl 1,
Trunk port 22 native_vlan 1 CBL 1
Trunk port 305 native_vlan 1 CBL 1
vsm-n1kv# sh int vethernet1
Vethernet1 is down (nonParticipating)
Port description is VMware VMkernel, vmk5
Hardware: Virtual, address: 0050.5662.3168 (bia 0050.5662.3168)
Owner is VMware VMkernel, adapter is vmk5
Inactive (last active on module 3)
VMware DVS port 196
Port-Profile is ucs-n1kv-L3control-vlan60
Port mode is access
5 minute input rate 0 bits/second, 0 packets/second
5 minute output rate 0 bits/second, 0 packets/second
Rx
25542 Input Packets 19766 Unicast Packets
0 Multicast Packets 5776 Broadcast Packets
5265560 Bytes
Tx
50273 Output Packets 7567 Unicast Packets
24912 Multicast Packets 17794 Broadcast Packets 42706 Flood Packets
6691492 Bytes
0 Input Packet Drops 0 Output Packet Drops
02-11-2013 05:44 PM
Veth1 is not your VSM's Control Interface. Look for Adapter1 of your VSM VM. vEth1 in your output is a VMK interface, likely the host's VMKernel for Mgmt, not the VSMs.
The VEM is programmed correctly. The CBL states are all FWD.
Can you check your licensing:
show mod
show license brief
show license usage
Can you also try a VSM switchover? "system switchover" in case its a stuck SVS Connection.
Robert
02-16-2013 02:27 PM
I am not seeing anything for
sh int virtual
vsm-n1kv# sh int virtual
Port Adapter Owner Mod Host
vsm-n1kv# show mod
2 0 Virtual Supervisor Module powered-up
Mod Sw Hw
vsm-n1kv# sh mod vem mapping
Mod Status UUID License Status
3 absent c6456f3e-2aa1-11e2-1100-00000000002f licensed
4 absent c6456f3e-2aa1-11e2-1100-00000000000e licensed
vsm-n1kv# sh mod vem missing
4 10.50.2.31 c6456f3e-2aa1-11e2-1100-00000000000e NA
3 10.50.2.30 c6456f3e-2aa1-11e2-1100-00000000002f NA
sh license brief is blank
vsm-n1kv# sh license usage
Feature Ins Lic Status Expiry Date Comments
Count
NEXUS_VSG_SERVICES_PKG No 512 Unused 05 Apr 2013 -
NEXUS1000V_LAN_SERVICES_PKG No 512 Unused 05 Apr 2013 -
NEXUS_ASA1000V_SERVICES_PKG No 16 Unused 05 Apr 2013 -
02-16-2013 02:28 PM
i noticed my control0 interface is down
vsm-n1kv# show system redundancy status
Redundancy role
administrative: primary
operational: primary
Redundancy mode
administrative: HA
operational: None
This supervisor (sup-1)
Redundancy state: Active
Supervisor state: Active
Internal state: Active with warm standby
Other supervisor (sup-2)
Redundancy state: Standby
Control connectivity is DOWN, Unable to get the status of the other supervisor.
I cannot ping the vmknic on control0
Also cannot take over by standby...
vsm-n1kv# system switchover
Failed to switch over (standby not ready to takeover)
02-17-2013 09:34 PM
I am seeing this in vsphere. The vlan on the control nics is showing vlan1. what is causing this?
