06-05-2013 11:37 AM - edited 03-01-2019 11:03 AM
I have booted from the esx disk and in the process of installing the software. It's asked me for the root password and when it goes to do the system Scan I get this error
<VALIDATE_HOST_HW ERROR: Vendor VIB for Hewlett-Packard Company found, but host is Cisco Systems Inc>
I've checked the compatibility matrix and I should be able to make this into a exsi 5.0.0 host, has anyone seen this?
I'm not sure if I read the matirx wrong .. or what.
Any help would be great.
BR
Solved! Go to Solution.
06-05-2013 12:21 PM
Which ISO are you using? We would expect using the Cisco OEM image
https://my.vmware.com/web/vmware/details?downloadGroup=CISCO-ESXI-5.0.0U2-GA-MAY2012&productId=229
06-05-2013 12:21 PM
