Prevent broadcast storm from VMs under FI
robad
We are having pair of Fabric-Interconnect 9296
On the blades, there ESXi installed, with VMs on it
Yesterday we had some network issues, and after 2 hours of T-Shoot, we get in to a point that we saw that there was a VM installed on some ESXi that used as a virtual switch, and it blows the whole subnet with Broadcast storm. We succeded with power off this VM, and now all is back to normal
How can we prevent things like that happened in the future ?
I know that on our Network Devices Env, we having a BPDU command on all of the user's interfaces to prevent it from happen, but what can I do here on a UCSM Env ?
Thanks a lot in advance,
Kirk J
There's nothing you can directly change on the vnic settings that's going to prevent you from creating loops/bridging at the guestVM level.
Some best practice things would be to limit the vlans allowed on the vnics to only the absolutely required vlans.  This will cut down on the amount of traffic, especially broadcast traffic, that is received at the ESXi host VMNIC level.
I see a lot of customers create service profiles early on in the design phase of their UCSMs, and virtually allow all the vlans because they haven't sorted out exactly which vlans are going to be used on which hosts.  Mis-configuration of vswitch teaming hashing algorithm, incorrect disjoint layer 2 config, upstream switching problems, can all potentially contribute to loss of traffic leaving the FIs, and cause a given guestVM to arp, re-arp trying to resolve basing mac/ip mapping.
Again, you need to fire up wireshark, and find out exactly what the nature of the traffic is, exact source mac addresss, which vlan, etc
There is a good forum post on how to do the vmware based captures at https://supportforums.cisco.com/t5/collaboration-voice-and-video/packet-capture-on-vmware-esxi-using-the-pktcap-uw-tool/ta-p/3165399
Kirk...
7 Replies 7
Kirk J
Greetings.
By design, the UCSM/FIs have several mechanisms including deja vu check, RPF check, that avoid loops.
If  you have misbehaving hosts or VMs that are continuously shooting out broadcast traffic, then the FIs are simply going to delivery the broadcast frames for that vlan.
I would take a wireshark capture of the traffic to confirm exactly what it is, and evaluate any guest VMs that have multiple NICs and have any sort of bridging config.
Kirk...
Hi, thanks for your reply,
When the BD happened, the whole subnet was down as you said.
If I understand right, there is no way to prevent the Broadcast storm on the vlan before it happens ?
Kirk J
Some routers/switches will have storm control.
The UCSM, which is designed to behave like an end host, maximum throughput, cut through switching, is not designed to do filtering or packet analysis.
These kinds of issues are usually due to improper network design/config.
If the broadcast storms are emanating from a guestVM, you could have a loop configured if multiple nics, or have an issue with the guestVM OS/app that is simply spitting out broadcast traffic (not necessarily related to a loop)
Kirk...
Hi Kirk, thanks again
I hope that I understood right...
So is there something I can configure on the SP's NIC that can minimize the impact ?
Kirk J
Kirk...
Thanks Kirk !
We always giving only the needed Vlan on the NIC
That's what caused that only one subnet was hurt
Thanks for your time
Hi Robab,
I agree that this is not necessarily a loop. We just encountered an ARP storm from multiple VMs that hit our upstream gateway router at such a high rate that it started dropping ARP. This affected all VLANs since the policer is not specific to VLAN. It actually affected dynamic routing peering as well when the ARP table needed to be updated for the peer. We are not using FI. We put in place storm-control to it's lowest limit which is still higher than the upstream Nexus 7K switch's ARP policer. We are now going to put in a custom policer that will limit VMWare MAC addresses at a lower threshold than the rest of the Nexus environment.
I would like to ask if you had implemented NSX-T prior to seeing the storm? We had done so and the hosts we have seen do this were on the NSX-T port groups. Apparently, the hosts were not getting the ARP reply from the gateway for what might be a bug on NSX-T and the host just kept ARPing for it. Why it needs to ARP at such an aggressive rate is beyond me. Not sure when NSX-T became available. It may be later than the time of your issue.
