10-24-2011 02:28 AM - edited 03-01-2019 10:07 AM
we have some UCS-B and some leds of their PSU's are blinking and the status is N/A. Status detailed can be seen in the screenshot:
The strange thing is this state doesn't generate any fault.
Does anyone know if PSU's are really working bad or is only a cosmetic issue?
Regards.
Solved! Go to Solution.
10-26-2011 11:07 AM
Had the same "problem" before.
When I passed a chassis the blinking PSU got my attention.
Our Cisco SE told me that this is a normal behaviour. When a PSU is not needed (depends on your power policy and installation order) it is switched to standby/power-save.
Nothing to worry about. Just a "green" behaviour.
Have a look at page 5
10-26-2011 11:07 AM
