08-06-2019 02:20 PM
We recently upgraded to 6332-16UP FIs, and would like to add some C220 rackmount servers to the domain using 2348UPQ FEX between the FIs and the rackmounts. I have been researching the best way to do this, but I am unclear about the configuration on the FEX. So if I configure the ports to the FEX from the FIs as server ports, and then have the Chassis discovery policy set to port-channel, do I need to configure anything on the FEX itself? Or is it like a IOM, and all config is through the FIs? I'd like to have two 40-Gbps uplinks connected to each FI. I found the documentation on setting up C-series servers, but am a little cloudy at how this part of the configuration is supposed to work. I'm using 4.0(4b) firmware. Thanks!
Solved! Go to Solution.
08-07-2019 04:19 AM
You do not need to configure anything on the FEX. As long as your link grouping preference is port-channel mode, you will see both links between FI and FEX form a port-channel once the FEX is discovered. To confirm, you can run 'show fex detail' once complete and you will see a Po under the outputs.
08-07-2019 04:19 AM
08-07-2019 08:59 AM
Thanks, Wes! I had seen some documentation about configuring FEX when connecting it to Nexus switches, and wanted to confirm that it worked more like a chassis IO Module in the UCS environment.
