09-30-2019 12:48 AM
I would like to know that, do we need to buy separate ESXi licenses if we deploy Cisco Hyperlex on VMware ?
Solved! Go to Solution.
09-30-2019 08:43 AM
That is generally true.
I believe that you would have had to purchase one of the OEM VMware licenses (HX-VSP.....) in order to purchase the ISV1 support.
There may be other options with the Solutions Support contracts, but you would want to contact your Cisco sales account team to see what options are available for your specific scenario.
Kirk...
09-30-2019 01:25 AM
HI @IC2317 ,
Cisco Hyperflex nodes come with a pre-installed Cisco specific version* of VMWare ESXi, and is fully functional using an evaluatoin licence. It is up to you to ensure that you have sufficient VMware ESXi licences to cover the ESXi nodes.
When ordering the ESXi package from Cisco, VMWare licencing is an added option you can choose. The advantage of buying the ESXi licences from Cisco is that you will get Cisco support for the Hyperflex AND VMware portions of your kit from the one place.
*ESXi nodes have the Hyperflex VIBs installed into operating system so you don't have to do it
I hope this helps
Don't forget to mark answers as correct if it solves your problem. This helps others find the correct answer if they search for the same problem
09-30-2019 01:42 AM
If we buy ESXi license from Cisco, does it mean that hypervisor level support will be provided by Cisco ?
09-30-2019 02:56 AM
Hi @IC2317 ,
Hopefully a Cisco employee will confirm, but my understanding is that Cisco will provide support for HX ESXi node Hypervisor related issues if you bought the licence through them. Many Cisco employees have a large degree of expertise with VMware - Cisco has been working closely with VMware for over a decade.
09-30-2019 04:35 AM - edited 10-01-2019 06:40 AM
In the VMware world, you have a license, which is a right to use software, and then you have support, which is an additional, separate item.
Cisco has options like ISV1 type contracts where Cisco TAC will triage and resolve most ESXi issues, and will involve VMware support on the back end if needed. Provides single point of contact scenario.
If you purchase no Vmware level support (or it's expired), then Cisco will still help triage and resolve Hyperflex related ESXi issues, but you will be expected to work with VMware to work through non-Hyperflex/UCS issues.
Kirk...
09-30-2019 05:22 AM
Thanks for the update. It means, If I use my existing VMware license on Hyperflex Servers then Cisco will only provide hyperflex related issues and for any issues related to Hypervisor we'll have to contact VMware ?
09-30-2019 08:43 AM
Kirk...
