08-02-2012 08:35 PM - edited 03-01-2019 10:32 AM
I had an ESXi host on a UCS blade and in that the VLAN 138 was configured right from the ESXi host. I rebuilt the blade as a physical Server 2008 host and the nic in the physical server under properties under Configure does not have the standard VLAN setting where I could set it to 138. I went to the service profile and changed the default vlan to 138 and reset the connectivity but I still cannot connect outside the server.
Update: I do not know what I did but I have one up and running. I guess my question is this. Does the server have to be rebooted if I make a change to a nic card through the profile in order for it to take effect?
08-02-2012 10:49 PM
Hello William,
If you are adding / removing VLANs to vNIC from service profile, it does not require reboot of the server.
Padma
08-06-2012 12:18 AM
Hi Padma/William
You might be having an initializing template rather than an updating one. That can be a reason why it might would have required a reboot. I am new to UCS. Tell me if I am wrong.
Tushir
08-06-2012 03:02 AM
You are right Tushir, It depends on the template used.
@ William::Well Is it possible for you to Acknowledge ur Chassis?
It might help to solve your problem.,,,,Well its just a try and dont forget that the entire Hardware Config will be re read if you acknowldege ur Chassis.
08-09-2012 06:54 PM
After building this server as a physcial 2008 server I had no better performance than the ESXi hosted VM's.
