Quick question - 5108 chassis max power
john.garrett
Hey guys, hopefully this is an easy one. What is the maximum power draw that a 5108 chassis can handle? In other words, how many amps can the chassis actually take? I thought I heard 32A at some point, but I can't find it in any documentation.
5 Replies 5
David Alpizar
John ,
The Cisco UCS 5108 Blade Server Chassis is powered by 208 V (220 V outside the US) 50-60 Hz AC. Up to four power supply units (PSUs) may be installed, each with a single C20 connector for input power connection to the UCS 5108 power supply.
Check the following document:
http://www.cisco.com/en/US/prod/collateral/ps10265/ps10280/UCS_Power_Supply_Configuration_and_Provisioning.pdf
Hope this helps!
That's not what I was asking. This isn't in any of the cisco documentation I've seen. It's an oddball question, so don't worry about it.
Scott Vartanian
Max power is 7500 watts assuming you are running four power supplies in N + 1 mode.
Tausif Gaddi
Hello John,
Please review this table, I hope this will help.
Description
Specification
AC-input   voltage
200   to 240 VAC nominal (Range: 180 to 264 VAC)
AC-input   frequency
50   to 60 Hz nominal (Range: 47 to 63 Hz)
AC-input current
15.5   Amps @ 200 VAC
Maximum   Input VA
2790   VA @ 200 VAC
Maximum output power per power supply
2500   W @ 200 to 240 VAC (up to four power supplies)
Maximum   inrush current
35   A
Maximum   Heat Output
8525   BTU
Maximum   hold up time
12   ms
Power supply output voltage
12   VDC
Efficiency   Rating
Climate   Savers Gold
Efficiency   (80Plus Gold Certified)
10%            20%           50%             100%
88.61%    91.64%   92.21%     90.97%
Input   connector
IEC320   C20
http://www.cisco.com/en/US/docs/unified_computing/ucs/hw/chassis/install/techspec.html
