06-27-2012 08:12 AM - edited 03-01-2019 10:28 AM
What is the recommended cabling and cable type for wiring up between a 5108 chassis and 6248?
06-27-2012 08:20 AM
If the devices are less than 10m apart (including cable management) then Twinax cabling (fixed length copper cable with built in transceivers) is recommended. It's far cheaper than optics, uses less power and has lower latency.
http://www.cisco.com/en/US/docs/unified_computing/ucs/hw/chassis/install/install.html#wp1330991
Robert
06-27-2012 09:15 AM
Thanks. Any reason for 10gig twinax over FC?
06-27-2012 09:35 AM
As I said previously:
-Twinax is cheaper
-Twinax uses less power
-Twinax has low latency
Robert
