12-10-2013 04:44 AM
I need help some help for UCS B series and C series device for getting the HBAs detail using MIB I have checked the cucsAdaptorHostFcIfTable table [CISCO-UNIFIED-COMPUTING-ADAPTOR-MIB ] where I able to get the details for HBAs but in the table it is returning WWN information, I have checked all the WWN available in the table cucsAdaptorHostFcIfWwn , cucsAdaptorHostFcIfOriginalNodeWwn ,cucsAdaptorHostFcIfOriginalWwn none of this is returning any value but cli has the information of the WWN below is the snipped from CLI
sjo-i1-fab1-A# scope adapter 2/1/1
sjo-i1-fab1-A /chassis/server/adapter # show host-fc-if
FC Interface:
Wwn: 20:02:07:97:A0:00:00:4E
Original Wwn: 20:00:00:26:51:09:5F:6C
Model: ISP2432-based 4Gb Fibre Channel to PCI Express HBA
Operability: Operable
Order: 3
PCI Addr: 04:00.0
Persistent Binding: Disabled
Side: Left
Max Data Field Size: 2048
Fabric ID: A
Port ID: 1
Slot ID: 1
Peer Port ID: 0
Peer Slot ID: 0
Peer Chassis ID: N/A
Current Task:
Wwn: 20:02:07:97:B0:00:01:4E
Original Wwn: 21:00:00:26:51:09:5F:6D
Order: 4
PCI Addr: 04:00.1
Side: Right
Fabric ID: B
Port ID: 2
Slot ID: 1
Peer Port ID: 0
Peer Slot ID: 0
Current Task:
So can anybody tell me If I am doing right MIB table query
Thank & Regards
Ruhul
Solved! Go to Solution.
12-11-2013 09:46 AM
Have you looked at: ftp://ftp.cisco.com/pub/mibs/supportlists/ucs/ucs-manager-supportlist.html
Also, all the right people are on this community forum who would know about SNMP, but you could also contact TAC or your account or channels team
12-10-2013 03:24 PM
If you are willing to use PowerShell with PowerTool for UCS I have a WWPN/WWNN collector tool posted on the communities site at: UCS WWPN Collector
I hope this helps you!
Joe
12-10-2013 09:26 PM
Thanks Joe,
But I need to collect it from SNMP as my application can connect the device via CLI or snmp.
Any point of contact for SNMP related information
Thanks & Regards
Ruhul
12-11-2013 09:46 AM
12-20-2013 11:54 PM
Thanks Joe,
Got help from UCS device bu that particular MIB file has some issue so they are check it.
Thanks & Regards
Ruhul
