02-28-2018 06:53 PM - edited 03-01-2019 01:27 PM
hi, I am wondering what is the best way to reinstall ESXi on a UCS C240.
If I "clear boot drive" using CIMC, does it kinda like format the logic disk? so that i can reinstall?
i need to reinstall a lower ESXi on a freshly installed UCS due to the vCentre's version lower than the installed ESXi.
Please advise..
thanks!
Solved! Go to Solution.
03-01-2018 03:34 AM
Greetings.
Mounting the ESXi install ISO via vKVM, and running the installer when existing partitions are present, will trigger a menu to choose from several options:
Either one of the "install" ESXi options will delete and recreate the OS and boot related partitions fresh.
the Preserve/overwrite datastore option lets you decide if you want to retain the datastore partitions if you have guest VMs stored there.
Kirk...
03-01-2018 02:50 PM
Correct. Press F6 during boot up and select the virtually mounted KVM vDVD/CD boot option if using vMedia. Run the ISO and follow the prompts and you'll be good.
03-01-2018 03:34 AM
Greetings.
Kirk...
03-01-2018 02:13 PM
Thanks Kirk,
How do I run the installer? boot from the mounted vDVD?
03-01-2018 02:50 PM
03-01-2018 03:21 PM
thanks guys,
i will give that a go.
