12-18-2018 01:25 PM
Is there anyway to non-disruptively remove a vNIC template from a vNIC tied to LAN Connectivity policy?
I need to enable failover on the fabric, but since a consultant wanted us to use the same vNIC template for ESX and a Windows SQL Baremetal blade, we now have a dilemma. ESX is using active/active so we had to disable failover, but active/active NIC teaming on Windows is causing MAC flapping since LACP is not supported on the FIs.
I am guessing I am going to have to create a new vNIC template, and change it on the LAN connectivity policy, but that is going to potentially cause some problems.
Any help is much appreciated.
12-18-2018 06:52 PM - edited 12-19-2018 04:19 AM
Greetings.
You are going to have to adjust multiple items...
I don't think you can avoid a reboot.
Theoretically, applying another lan connectivity policy with same number of vnics, with same eth names, referencing the same MAC pools, 'might' apply without a reboot, but I doubt it. Enabling 'failover' always requires a reboot regardless.
Kirk...
12-19-2018 07:12 AM
Thanks, yeah I don't mind a reboot. I am just worried about re-ordering of vNICS, and MAC address changes since they are tied to a NIC team on the Windows side. There are separate SP templates for the ESX and Windows, they are just using a common vNIC template which is the problem.
12-18-2018 08:49 PM
You can't enable fabric failover on vNICs without reboot of server.
MJ
