reused hardware
We are planning to upgrade blade servers from b200 m4 to m6 series.
I am confused here, can we use m4 series ram,cpu,disk and vic card in m6 series?
Steven Tardy
For some of the parts, for sure will NOT function.
For some of the parts, might work but none are officially supported.
  • CPUs are 100% physically/mechanically/electrically/software-BIOS incompatible.
  • M6 disks are slimmer as SSD height is shorter than a mechanical HDD which was common when M4s were designed.
  • DIMMs might work, but M4 DIMMs are much slower than modern M6 DIMMs.
  • The only VIC on the B200 M6 spec sheet is the 4th gen VIC 1440, whereas the B200 M4 spec sheet only shows up to the 3rd gen 1340/1380.
Unfortunately you are better off getting all new parts.
Can do hand-me-down hardware and keep the M4s running in a test/dev cluster.
AFAIK, its not possible. Moving this thread to DC community.
Response Signature
Steven Tardy
Thanks Steven for answer.
