04-30-2021 09:54 AM
Can anyone confirm if a breakout cable is supported by the S3260 storage server with an embedded VIC1300? This will uplink to a 6454 FI. The datasheet and spec sheets don't seem to confirm this detail.
Solved! Go to Solution.
04-30-2021 11:28 AM
04-30-2021 11:25 AM
Can you confirm the type of optics/cables you are attempting to use?
04-30-2021 01:04 PM
Wes, the type of optic isn't set in stone yet but we are considering a QSFP+ breakout cable. Based on that compatibility matrix you shared, it looks like it will work just fine with the 6400 FI. Thank you for sharing that. I did a lot of searching but didn't think to look in the configuration guide.
04-30-2021 11:28 AM
