SAN Port-Channel - No Operational Members
John Early
I am trying to setup a FC port-channel between a UCS and N5k.  Environment is UCS 2.0(3c), 6248s, 5548s, EMC VNX 5300.  When I leave the FC uplinks out of the port channel they work fine, no errors and I get successful flogi.  When I setup the port-channel on both the UCS and N5k I get "Failed - No Operational Members" error code F0282.  Here is the port-channel summary info and port configuration from both the UCS and N5k, both fabric A and fabric B have the same problem, this is the config of only A both are the same.
UCSM-A(nxos)# show san-port-channel sum
U-Up D-Down B-Hot-standby S-Suspended I-Individual link
summary header
Group  Port-      Type     Protocol  Member Ports
       Channel
121    San-po121            FC      PCP      (D)  FC       fc1/31(D)    fc1/32(D)
interface san-port-channel 121
  channel mode active
  switchport mode NP
interface fc1/31
  channel-group 121 force
  no shutdown
interface fc1/32
  no shutdown
NEXUS-01# show san-port-channel sum
summary header
       Channel
11     San-po11   FC      PCP      (D)  FC       fc1/31(D)    fc1/32(D)
interface san-port-channel 11
  channel mode active
interface fc1/31
  channel-group 11 force
  no shutdown
interface fc1/32
  no shutdown
Thank you for the help!
Hello John
Can you verify whether you have enabled fport-channel-trunk on the N5K switch ?
           show feature
If not,please enable it by
          conf t
          feature fport-channel-trunk
Then do a shut / no shut for the port channel interface.
Padma
7 Replies 7
padramas
John,
Can you please paste the output of following commands from FI and N5K
show int san-port-channel 121
show int fc 1/31
show int san-port-channel 11
show int fc 1/31
Padma
This is still John, having problems with my CCO account so I borrowed one to post back.  Here are the interface outputs:
UCSM-A(nxos)# show int san-port-channel 121
san-port-channel 121 is down (No operational members)
    Hardware is Fibre Channel
    Port WWN is 24:79:54:7f:ee:aa:78:00
    Admin port mode is NP, trunk mode is off
    snmp link state traps are enabled
    Port vsan is 20
    1 minute input rate 0 bits/sec, 0 bytes/sec, 0 frames/sec
    1 minute output rate 0 bits/sec, 0 bytes/sec, 0 frames/sec
      331 frames input, 158436 bytes
        7 discards, 0 errors
        0 CRC,  0 unknown class
        0 too long, 0 too short
      322 frames output, 18140 bytes
        0 discards, 0 errors
      3 input OLS, 3 LRR, 3 NOS, 0 loop inits
      7 output OLS, 3 LRR, 5 NOS, 0 loop inits
    last clearing of "show interface" counters never
    Member[1] : fc1/31
    Member[2] : fc1/32
UCSM-A(nxos)# show int fc 1/31
fc1/31 is down (Link failure or not-connected)
    Hardware is Fibre Channel, SFP is short wave laser w/o OFC (SN)
    Port WWN is 20:1f:54:7f:ee:aa:78:00
    Port vsan is 20
    Receive data field Size is 2112
    Beacon is turned off
    Belongs to san-port-channel 121
      328 frames input, 158016 bytes
        5 discards, 0 errors
      320 frames output, 17852 bytes
      2 input OLS, 2 LRR, 2 NOS, 0 loop inits
      5 output OLS, 2 LRR, 3 NOS, 0 loop inits
    Interface last changed at Thu Sep  6 08:50:09 2012
UCSM-A(nxos)# show int fc 1/32
fc1/32 is down (Link failure or not-connected)
    Port WWN is 20:20:54:7f:ee:aa:78:00
    Port vsan is 20
      343 frames input, 159156 bytes
        6 discards, 0 errors
      333 frames output, 18744 bytes
      4 output OLS, 1 LRR, 2 NOS, 0 loop inits
    Interface last changed at Thu Sep  6 08:50:10 2012
NEXUS-01# show interface san-port-channel 11
san-port-channel 11 is down (No operational members)
    Port WWN is 24:0b:54:7f:ee:65:be:c0
    Admin port mode is auto, trunk mode is on
    Port vsan is 20
      971 frames input, 55612 bytes
      1029 frames output, 489688 bytes
      15 input OLS, 5 LRR, 493 NOS, 0 loop inits
      73 output OLS, 16 LRR, 485 NOS, 0 loop inits
    Member[1] : fc1/31
    Member[2] : fc1/32
NEXUS-01# show int fc 1/31
fc1/31 is down (Error disabled - Possible port channel misconfiguration)
    Port WWN is 20:1f:54:7f:ee:65:be:c0
    Port vsan is 20
    Belongs to san-port-channel 11
      969 frames input, 55324 bytes
      1027 frames output, 489400 bytes
      14 input OLS, 4 LRR, 449 NOS, 0 loop inits
      67 output OLS, 16 LRR, 443 NOS, 0 loop inits
    Interface last changed at Fri Aug 14 12:38:22 2009
NEXUS-01# show int fc 1/32
fc1/32 is down (Error disabled - Possible port channel misconfiguration)
    Port WWN is 20:20:54:7f:ee:65:be:c0
    Port vsan is 20
      978 frames input, 55840 bytes
      1037 frames output, 489600 bytes
      11 input OLS, 3 LRR, 463 NOS, 0 loop inits
      65 output OLS, 15 LRR, 458 NOS, 0 loop inits
    Interface last changed at Fri Aug 14 12:38:23 2009
John
Hello John
           show feature
          conf t
Padma
feature fport-channel-trunk is not enabled.  Is there any loss of connectivity when this is enabled??
John
John,
Enabling fport-channel-trunk feature does not affect any existing traffic.
It is required to form port-channel between FI ( NPV with NP ports ) and N5K ( NPIV switch with F ports )
Padma
Finally got my CCO account working again...
I will enable this feature and report back if it worked or not.
John
Had to wait for a maintenance window to enable the feature just to be on the safe side. Once enabled I bounced the ports on each side and everything is up and running now.
