I am trying to setup a FC port-channel between a UCS and N5k. Environment is UCS 2.0(3c), 6248s, 5548s, EMC VNX 5300. When I leave the FC uplinks out of the port channel they work fine, no errors and I get successful flogi. When I setup the port-channel on both the UCS and N5k I get "Failed - No Operational Members" error code F0282. Here is the port-channel summary info and port configuration from both the UCS and N5k, both fabric A and fabric B have the same problem, this is the config of only A both are the same.
UCSM-A(nxos)# show san-port-channel sum
U-Up D-Down B-Hot-standby S-Suspended I-Individual link
summary header
Group Port- Type Protocol Member Ports
Channel
121 San-po121 FC PCP (D) FC fc1/31(D) fc1/32(D)
interface san-port-channel 121
channel mode active
switchport mode NP
interface fc1/31
channel-group 121 force
no shutdown
interface fc1/32
no shutdown
NEXUS-01# show san-port-channel sum
summary header
Channel
11 San-po11 FC PCP (D) FC fc1/31(D) fc1/32(D)
interface san-port-channel 11
channel mode active
interface fc1/31
channel-group 11 force
no shutdown
interface fc1/32
no shutdown
Thank you for the help!
Solved! Go to Solution.
Hello John
Can you verify whether you have enabled fport-channel-trunk on the N5K switch ?
show feature
If not,please enable it by
conf t
feature fport-channel-trunk
Then do a shut / no shut for the port channel interface.
Padma
John,
Can you please paste the output of following commands from FI and N5K
show int san-port-channel 121
show int fc 1/31
show int san-port-channel 11
show int fc 1/31
Padma
This is still John, having problems with my CCO account so I borrowed one to post back. Here are the interface outputs:
UCSM-A(nxos)# show int san-port-channel 121
san-port-channel 121 is down (No operational members)
Hardware is Fibre Channel
Port WWN is 24:79:54:7f:ee:aa:78:00
Admin port mode is NP, trunk mode is off
snmp link state traps are enabled
Port vsan is 20
1 minute input rate 0 bits/sec, 0 bytes/sec, 0 frames/sec
1 minute output rate 0 bits/sec, 0 bytes/sec, 0 frames/sec
331 frames input, 158436 bytes
7 discards, 0 errors
0 CRC, 0 unknown class
0 too long, 0 too short
322 frames output, 18140 bytes
0 discards, 0 errors
3 input OLS, 3 LRR, 3 NOS, 0 loop inits
7 output OLS, 3 LRR, 5 NOS, 0 loop inits
last clearing of "show interface" counters never
Member[1] : fc1/31
Member[2] : fc1/32
UCSM-A(nxos)# show int fc 1/31
fc1/31 is down (Link failure or not-connected)
Hardware is Fibre Channel, SFP is short wave laser w/o OFC (SN)
Port WWN is 20:1f:54:7f:ee:aa:78:00
Port vsan is 20
Receive data field Size is 2112
Beacon is turned off
Belongs to san-port-channel 121
328 frames input, 158016 bytes
5 discards, 0 errors
320 frames output, 17852 bytes
2 input OLS, 2 LRR, 2 NOS, 0 loop inits
5 output OLS, 2 LRR, 3 NOS, 0 loop inits
Interface last changed at Thu Sep 6 08:50:09 2012
UCSM-A(nxos)# show int fc 1/32
fc1/32 is down (Link failure or not-connected)
Port WWN is 20:20:54:7f:ee:aa:78:00
Port vsan is 20
343 frames input, 159156 bytes
6 discards, 0 errors
333 frames output, 18744 bytes
4 output OLS, 1 LRR, 2 NOS, 0 loop inits
Interface last changed at Thu Sep 6 08:50:10 2012
NEXUS-01# show interface san-port-channel 11
san-port-channel 11 is down (No operational members)
Port WWN is 24:0b:54:7f:ee:65:be:c0
Admin port mode is auto, trunk mode is on
Port vsan is 20
971 frames input, 55612 bytes
1029 frames output, 489688 bytes
15 input OLS, 5 LRR, 493 NOS, 0 loop inits
73 output OLS, 16 LRR, 485 NOS, 0 loop inits
Member[1] : fc1/31
Member[2] : fc1/32
NEXUS-01# show int fc 1/31
fc1/31 is down (Error disabled - Possible port channel misconfiguration)
Port WWN is 20:1f:54:7f:ee:65:be:c0
Port vsan is 20
Belongs to san-port-channel 11
969 frames input, 55324 bytes
1027 frames output, 489400 bytes
14 input OLS, 4 LRR, 449 NOS, 0 loop inits
67 output OLS, 16 LRR, 443 NOS, 0 loop inits
Interface last changed at Fri Aug 14 12:38:22 2009
NEXUS-01# show int fc 1/32
fc1/32 is down (Error disabled - Possible port channel misconfiguration)
Port WWN is 20:20:54:7f:ee:65:be:c0
Port vsan is 20
978 frames input, 55840 bytes
1037 frames output, 489600 bytes
11 input OLS, 3 LRR, 463 NOS, 0 loop inits
65 output OLS, 15 LRR, 458 NOS, 0 loop inits
Interface last changed at Fri Aug 14 12:38:23 2009
John
Hello John
show feature
conf t
Padma
feature fport-channel-trunk is not enabled. Is there any loss of connectivity when this is enabled??
John
John,
Enabling fport-channel-trunk feature does not affect any existing traffic.
It is required to form port-channel between FI ( NPV with NP ports ) and N5K ( NPIV switch with F ports )
Padma
Finally got my CCO account working again...
I will enable this feature and report back if it worked or not.
John
Had to wait for a maintenance window to enable the feature just to be on the safe side. Once enabled I bounced the ports on each side and everything is up and running now.
