804
Highlighted
Beginner
Scripting UCS FI 2.x NX-OS Commands
Has anyone successfully scripted UCS 2.x NX-OS commands (such as show system uptime, and show platform software cmccrtl process meminfo | i MemFree) that can be run across multiple domains which passes credentials?  Apparently cannot be done using PowerTools.  It would be helpful to regularly run certain commands that do not exist in PowerTools to assess the health of memory usage and system up time.
Everyone's tags (2)
1 REPLY 1
Beginner
Re: Scripting UCS FI 2.x NX-OS Commands
I do not know how robust this solution will end up but you can run ssh commands from powershell using WMF 5 and the Posh-SSL Cmdlets.
https://www.powershellgallery.com/GettingStarted?section=Get%20Started
https://www.powershellgallery.com/packages/Posh-SSH/
# Getting SSH Command Info from UCS via Powershell
# Needs:
# https://www.powershellgallery.com/packages/Posh-SSH/
# See getting started to install WMF 5.0
# 1/6/2016 - Larry Hedrick
# Begin
Write-Host "Connecting to UCSM..." -ForegroundColor Cyan
New-SSHSession -ComputerName 'dat01-clucs-003'
Write-Host "Running Commands..." -ForegroundColor Cyan
Invoke-SSHCommand -Command 'show cluster state' -SessionId '0' | select -ExpandProperty Output
Write-Host "Disconnecting." -ForegroundColor Cyan
Remove-SSHSession -SessionId 0
#end
Output
cmdlet New-SSHSession at command pipeline position 1
Supply values for the following parameters:
SessionId  Host                                                          Connected
    0      dat01-clucs-003                                                 True
Running Commands...
Cluster Id: 0xfa5cfdda8dd511e3-0xb6bc000573e36044
B: UP, PRIMARY
A: UP, SUBORDINATE
HA READY
Disconnecting.
True
Content for Community-Ad
August's Community Spotlight Awards
