Greetings.
I would open a TAC case, and have them review the CIMC logs.
If your ROC chip on the raid controller hits 85 degrees, it will cause the Rack server to rev the fans really high.
Depending on your CIMC version, if you have versions under 2.03i, you can run into memory leak conditions in the CIMC. During memory leak conditions you can get a variety of Fan control issues, where they stay maxed out.
Short term, you may want to reboot the CIMC under the Admin Tab, Utilities, reboot CIMC. This does not require an outage, as the Server itself will stay powered on, and OS will continue to run.
If this resolves it short term, then I would consider upgrading to a CIMC version of 2.03i or higher.
Kirk...
