09-28-2020 07:29 PM
Want to ask why does the cimc refusing connection and giving an error 0x18008080 and then makes the server super noisy? Any solution for this problem?
Solved! Go to Solution.
09-30-2020 09:30 AM
Ah.
so I'm guessing the actual removal of the Cr2032 battery is probably what helped reset a cmos setting.
Glad to hear it is resolved.
Kirk...
09-28-2020 07:54 PM
Refer to Cisco IMC refusing connections on C220M4
You might want to engage TAC.
09-29-2020 03:58 AM
I have seen a mix of issues cause that particular error/scenario.
If you have physical access to the server, I would try a USB base HUU upgrade (use Rufus or similar app to apply HUU to USB stick).
The Fans stay high when the CIMC is not functioning correctly (i.e this scenario, memleak), or unmanaged PCI-E cards are present.
Did any activity immediately predate this condition (i.e. HUU upgrade)?
You will need to work with TAC to determine correct action plan.
Kirk...
09-29-2020 04:58 AM
How to perform HUU Upgrade when you turned on the machine the only word that will prompt in the monitor is error 0x18008080 the serial no. is XXXXXXXXXXXX?
09-29-2020 06:02 AM
If you are only getting that, and no BIOS post sequences, then sounds like RMA is probably in order.
I would do hard power cycle, remove CMOS battery for a couple of minutes.
if no go,,, then TAC case.
Kirk...
09-29-2020 07:17 PM
I've fixed the problem now by replacing the CMOS Battery a new one.
Thanks.
09-30-2020 09:30 AM
Ah.
Kirk...
