08-23-2013 03:41 AM - edited 03-01-2019 11:12 AM
Hi all
when deploying the VSM on a Standard Switch, is it a requirement to include System VLAN's for my the packet and control VLAN's in the Port-Profiles on the dvs?
Many thanks
08-23-2013 05:51 AM
Hi Ronan,
Yes, you still need to define control and packet VLANs as system VLANs on the uplink Ethernet port-profile that you use.
This is needed for the VEM to communicate with the VSM (that's on the standard switch).
Shankar
08-23-2013 06:17 AM
Great thanks
Am i correct in saying that all other VLAN's (except Mgmt) should not be declared as System VLANs if we implement QoS etc?
08-23-2013 06:50 AM
Correct. You only want system VLANs on the VLANs that are needed to bootstrap the 1000v.
The normal port-profiles that would be used with your VMs typically don't require a system VLAN.
In fact, if you enable a system VLAN on an interface that is going to implement access lists or QoS and there is a problem programming the interface, the port will still forward on that system VLAN, but none of the access lists or QoS settings will be in place.
