03-15-2012 09:26 AM - edited 03-01-2019 10:19 AM
Hi All,
I do not have a VCP yet so will I be allowed at least to take the UCS test?
Does Cisco has a system such as they will allow us to take the UCS test but they will not certify us unless we are VCP.
Ismail
Solved! Go to Solution.
03-15-2012 10:11 AM
Hi Ismail
You can still take the test, and still qualify as both a Cisco Unified Computing Technology Design Specialist and a Cisco Unified Computing Technology Support Specialist without a VCP.
But if you are after Cisco Data Centre Unified Computing Support Specialist and the like then yes VCP is still a pre-req (I have heard that this may possibly be dropped in favour of a Cisco administered equivilent, but thats unsubstantiated)
Unfortunatley (as I found) just passing the VCP exam was not enough, but the VMware course is also a mandatory VMware requirement for VCP.
Good luck with it.
Colin
03-15-2012 10:11 AM
Hi Ismail
Good luck with it.
Colin
