03-16-2016 03:31 AM - edited 03-01-2019 12:38 PM
I am trying to install W2K12R2 on my UCS C220 M4S server and I have configured a Virtual Drive(mirrored 2 physical Drives) on my Cisco 12G SAS Module Raid Controller, I then boot up with my ISO of W2K12R2 and get to the point where I am to identify which drive to install Windows on, there is only the one drive, when it comes up I get the warning Windows Can't be installed on Drive 0 Partition 1 (Show details) See UCS-ATTACH1 in Attachments.
I figured it was probably a driver related issues and downloaded the driver pack cxxx-scu-drivers-w2k12r2x64-3.0.8a and hunted for the drivers, Tried
see UCS-ATTACH2
Also tried both drives on UCS-ATTACH3
Is there a setting in BIOS I have missed?
03-17-2016 04:32 AM
Did you have to attach the CD-ROM ISO? Did you remember to reconnect the Windows ISO once you loaded the drivers? I can't tell you how many times I did that before I got frustrated and added the UCS drivers to the Windows install disk.
03-17-2016 12:21 PM
James,
Is the VD you are attempting to install to configured as a bootable drive?
You could also try running the SCU (server configuration utility) to see if that works for you.
03-17-2016 05:28 PM
After creating VD , Do you configure set as a boot device ??
http://www.cisco.com/c/en/us/td/docs/unified_computing/ucs/c/sw/gui/config/guide/2-0/b_Cisco_UCS_C-series_GUI_Configuration_Guide_201/b_Cisco_UCS_C-series_GUI_Configuration_Guide_201_chapter_010011.html#task_D9EE704B331C4328B7107B54776E2EA8
03-18-2016 12:24 PM
Try with disabled uEFI in bios, reboot and then try.
