10-11-2021 10:09 PM
I have a customer with a Cisco UCSM:
2x Fibre Interconnects
2x Chassis
6x B-series blade servers
The customer currently has firmware 3.2(3p) on their system and would like to upgrade to V4.1 (N-1) as they are upgrading their vSphere environment to 6.7u3.
From what I can see on the Cisco Downloads site, the following software is available (N-1):
Infrastructure firmware 4.1(3f)
Blades firmware 4.1(3f)
Blades ESXi drivers 4.1(3n)
Considering I will be upgrading the Infrastructure & Blade firmware to 4.1(3f), which ESXi drivers should I use for the ESXi hosts? Is the minimum driver I can use 4.1(3f) and the latest 4.1(3n) OK to use and how do I choose which one without losing compatibility between the drivers and the firmware?
Solved! Go to Solution.
10-12-2021 05:05 AM - edited 10-12-2021 05:09 AM
One you have picked a firmware version, use the HCL tool to confirm the driver version that is applicable.
https://ucshcltool.cloudapps.cisco.com/public/#
You base your 'firmware version' for driver/HCL purposes on the blade/rack firmware bundle version.
Generally, driver versions will not distinguish between minor firmware revisions (i.e. 4.13f vs 4.13n)
Kirk...
Kirk...
10-12-2021 04:53 PM
Thanks. I put in the following information:
Server Type: B-Series
Server Model: Cisco UCS B200 M5 2 socket blade server
Processor Version: Intel Xeon Processor Scalable Family (the CPU is actually an Intel Xeon Gold 6132)
Operating System: VMware
Operating System Version: 6.7U3
From the results shown, I checked the UCS Server Firmware 4.1(3) and the following was provided:
Firmware Bundle: https://software.cisco.com/download/home/283853163/type/283655681/release/4.2(1f)
Driver ISO: https://software.cisco.com/download/home/283853163/type/283853158/release/4.1(3n)
For the Driver ISO, I understand that I can use the 4.1.3n bundle to inject the required drivers into the ESXi hosts- this is OK. I guess this answers my question!
