Turbo Boost for Intell CPUs on UCS M4 Blade Server
rumak18
Hi there,
my hypervisor "Hyper-V 2012R2" don't use Turbo Boost. I have a intel V3 CPU that stocks at 2,4 GHZ instead of boosting while benchmarking to 3,5 GHZ.  I see this behaviour in Task Manager and CPU-Z.
In Service Profile i see that "turbo boos" is checked as "enabled".
7 Replies 7
mojafri
Hi @rumak18,
Do you have Intel SpeedStep set as "Disabled"?. Intel Turbo Boost depends on Intel SpeedStep and if you want to enable Turbo Boost, you must enable SpeedStep first.
Please rate if you find it helpful.
MJ
yes, SppedStep ist enabled. I've read some articles about "C" and "P" States...not quite sure what to configure here as some people state to disable it and others state to enable it.
Hi @rumak18,
Please share below details:
1. Blade model
2. CPU model
3. BIOS or blade firmware
4. Command output from CLI-
# scope org
# scope bios-policy <policy-name>
# show expand detail
MJ
  Ok, here is the output:
1. UCSB-B200-M3
2. Intel E5 2690v3
3. B200M3.2.2.6d.0.062220160055
4. Command output CLI
BIOS Policy:
    Description:
    Reboot on BIOS Policy Change: No
    Policy Owner: Local
    Acpi10 Support Config:
        Acpi10 Support: Platform Default
    Aspm Support Config:
        Aspm Support: Platform Default
    All Usb Devices Config:
        All Usb: Platform Default
    Altitude:
        Altitude Config: Platform Default
    Assert NMI On PERR Config:
        Assertion: Platform Default
    Assert NMI On SERR Config:
    Boot Option Retry Config:
        Retry: Platform Default
    Cpu Hardware Power Management Config:
        Cpu Hardware Power Management: Platform Default
    Cpu Performance Config:
        Cpu Performance: Enterprise
    Cpu Power Management Config:
        Cpu Power Management: Platform Default
    Consistent Device Name Control:
        Cdn Name: Platform Default
    Console Redir Config:
        Console Redir: Platform Default
        Flow Control: Platform Default
        Baud Rate: Platform Default
        Terminal Type: Platform Default
        Legacy Os Redir: Platform Default
        Putty Function Keypad: Platform Default
    Core Multi Processing Config:
        Multi Processing: All
    Ddr3 Voltage Config:
        Ddr3 Voltage: Platform Default
    Dram Clock Throttling Config:
        Dram Clock Throttling: Performance
    Direct Cache Access Config:
        Access: Enabled
    Dram Refresh Rate Config:
        Dram Refresh: Auto
    Power Performance Tuning Support:
        Power Performance Tuning Config: Platform Default
    Enhanced Intel Speedstep Config:
        Speed Step: Enabled
   Enhanced Powercapping Support:
        Enhanced Powercapping Config: Platform Default
    Execute Disable:
        Bit: Enabled
    Frb 2 Timer Config:
        Frb 2 Timer: Platform Default
    Frequency Floor Override Config:
        Cpu Frequency: Platform Default
    Front Panel Lockout Config:
        Front Panel Lockout: Platform Default
    Ioemezz1 Optionrom Config:
        Ioemezz1 Optionrom: Platform Default
    Ioenvme1 Optionrom Config:
        Ioenvme1 Optionrom: Platform Default
    Ioenvme2 Optionrom Config:
        Ioenvme2 Optionrom: Platform Default
    Ioeslot1 Optionrom Config:
        Ioeslot1 Optionrom: Platform Default
    Ioeslot2 Optionrom Config:
        Ioeslot2 Optionrom: Platform Default
    Integrated Graphics Config:
        Integrated Graphics: Platform Default
    Integrated Graphics Aperture Config:
        Integrated Graphics Aperture: Platform Default
    Intel Entry SAS Raid Config:
        Sas Raid: Disabled
        Sas Raid Module: Platform Default
    Hyper Threading Config:
        Hyper Threading: Enabled
    Intel Trusted Execution Technology Config:
       Txt Support: Platform Default
    Intel Turbo Boost Config:
        Turbo Boost: Enabled
    Intel Vt Directed Io Config:
        Vtd: Enabled
        Interrupt Remapping: Enabled
        Coherency Support: Enabled
        Ats Support: Enabled
        Passthrough Dma: Enabled
    Intel Vt Config:
        VT: Enabled
    Interleave Config:
        Memory Interleave: Platform Default
        Channel Interleave: Auto
        Rank Interleave: Auto
    Local X2 Apic Config:
        Localx2 Apic: Auto
    Lv Dimm Support Config:
        Lv Ddr Mode: Performance Mode
    Max Variable Mtrr Setting Config:
        Processor Mtrr: Auto Max
    Max Memory Below 4GB Config:
        Max Memory: Platform Default
    Memory Mapped IO Above 4GB Config:
        Memory Mapped IO: Platform Default
    Memory Mirroring Mode:
        Mirroring Mode: Platform Default
    NUMA Config:
        NUMA Optimization: Enabled
    Os Boot Watchdog Timer Config:
        Os Boot Watchdog Timer: Platform Default
    Os Boot Watchdog Timer Policy Config:
        Os Boot Watchdog Timer Policy: Platform Default
    Os Boot Watchdog Timer Timeout Config:
        Os Boot Watchdog Timer Timeout: Platform Default
    Onboard Graphics Config:
        Onboard Graphics: Platform Default
    Onboard Sata Ctrl Config:
        Sata Ctrl: Platform Default
        Sata Mode: Platform Default
    Onboard Sas Storage Config:
        Onboard Sas Ctrl: Platform Default
    Option Rom Enable Config:
        Option Rom Enable: Platform Default
    Option Rom Load Config:
        Option Rom Load: Platform Default
    Com Spcr Enable:
        Com Spcr Enable Config: Platform Default
    Sata Mode Select Config:
        Sata Mode Select: Platform Default
    Lom Ports Config:
        Pcie Lom2 Link: Platform Default
    PCI ROM CLP Support:
        PCI ROM CLP Config: Platform Default
    Slot Link Speed Config:
        Pcie Slot1 Link Speed: Platform Default
        Pcie Slot2 Link Speed: Platform Default
        Pcie Slot3 Link Speed: Platform Default
        Pcie Slot4 Link Speed: Platform Default
        Pcie Slot5 Link Speed: Platform Default
        Pcie Slot6 Link Speed: Platform Default
        Pcie Slot7 Link Speed: Platform Default
        Pcie Slot8 Link Speed: Platform Default
        Pcie Slot9 Link Speed: Platform Default
        Pcie Slot10 Link Speed: Platform Default
    Slot Option Rom Enable Config:
        Slot1 Option Rom Enable: Platform Default
        Slot2 Option Rom Enable: Platform Default
        Slot3 Option Rom Enable: Platform Default
        Slot4 Option Rom Enable: Platform Default
        Slot5 Option Rom Enable: Platform Default
        Mezz Slot Option Rom Enable: Platform Default
        Slot6 Option Rom Enable: Platform Default
        Slot7 Option Rom Enable: Platform Default
        Pcie Sas: Disabled
        Slot8 Option Rom Enable: Platform Default
        Slot9 Option Rom Enable: Platform Default
        Slot10 Option Rom Enable: Platform Default
        Pcie Mlom: Platform Default
        Pcie Hba: Platform Default
        Pcie N1: Platform Default
        Pcie N2: Platform Default
    Post Error Pause Config:
        Post Error Pause: Platform Default
    P State Coordination Config:
        P State: Platform Default
    Package C State Limit Config:
        Package C State Limit: Platform Default
    Processor C1e Config:
        C1e: Enabled
    Processor C3 Report Config:
        Processor C3 Report: Acpi C3
    Processor C6 Report Config:
        Processor C6 Report: Enabled
    Processor C7 Report Config:
        Processor C7 Report: Enabled
    Processor Cmci Config:
        Processor Cmci: Platform Default
    Processor C State Config:
        C State: Enabled
    Processor Energy Config:
        Cpu Power Management: Performance
        Energy Performance: Performance
    Processor Prefetch Config:
        Hardware Prefetch: Platform Default
        Adjacent Cache Line Prefetch: Platform Default
        Dcu Streamer Prefetch: Platform Default
        Dcu Ip Prefetch: Platform Default
    Qpi Link Frequency Select Config:
        Qpi Link Frequency MT Per Sec: Auto
    Qpi Snoop Mode:
        Vp QPI Snoop Mode: Platform Default
    Quiet Boot Config:
        Quiet Boot: Disabled
    Redirection After Post Support:
        Redirection After Post Config: Platform Default
    Resume AC On Power Loss Config:
        Resume Action: Platform Default
    Sbmezz1 Optionrom Config:
        Sbmezz1 Optionrom: Platform Default
    Sbnvme1 Optionrom Config:
        Sbnvme1 Optionrom: Platform Default
    Sioc1 Optionrom Config:
        Sioc1 Optionrom: Platform Default
    Sioc2 Optionrom Config:
        Sioc2 Optionrom: Platform Default
    Scrub Policies Config:
        Patrol Scrub: Platform Default
        Demand Scrub: Platform Default
    Memory Ras Config:
        Ras Config: Maximum Performance
    Serial Port A Config:
        Serial Port A: Platform Default
    Memory Sparing Mode:
        Sparing Mode: Platform Default
    Sriov Config:
        Sriov: Platform Default
    Vf TPM Pending Operation:
        Vp TPM Pending Operation: Platform Default
    Tpm Support Select Config:
        Tpm Enable Disable: Platform Default
    Trusted Platform Module Config:
        Tpm State: Platform Default
    Ucsm Boot Mode Control Config:
        Uefi Boot Mode: Platform Default
    Ucsm Boot Order Rule Control Config:
        Ucsm Boot Order Rule: Platform Default
    Uefi Os Legacy Video Config:
        Legacy Video: Platform Default
    Usb Boot Config:
        Make Device Non Bootable: Disabled
        Legacy Support: Auto
    Usb Configuration Select Config:
        Legacy Usb Enable Disable: Platform Default
        Xhci Enable Disable: Platform Default
    Usb Front Panel Access Lock Config:
        Usb Front Panel Lock: Platform Default
    Usb Port Config:
        Usb Emulation: Platform Default
        Usb Rear: Platform Default
        Usb Front: Platform Default
        Usb Internal: Platform Default
        Usb Kvm: Platform Default
        Usb Vmedia: Platform Default
        Usb Sdcard: Platform Default
    Usb System Idle Power Optimizing Setting Config:
        Usb Idle Power Optimizing: Platform Default
    Vga Priority Config:
        Vga Priority: Platform Default
    Workload Configuration Config:
        Workload Configuration: Platform Default
There is not much that can go wrong with this configuration right?
@rumak18,
Change "CPU performance" to HPC and disable C state. After making the changes get me the below output from cmd.
powercfg /GETACTIVE
MJ
OK, done and the result is "high performance" , but the result is still the same.
