TWO HX-E-220M5SX Edge dEPLOYMENT WITH ova INSTALLER
Mohammed786
Hi aLL
I have 2 node HX-E-220M5SX Edge and I am trying to install Hyperflex. I am getting below error for entering third node IP address details.
Please advice how can install hyperflex with two-node WITH hYPERFLEX INSTALLER(OVA)
I have chosen the edge cluster.
Kirk J
Please check the requirements section of https://www.cisco.com/c/en/us/td/docs/hyperconverged_systems/HyperFlex_HX_DataPlatformSoftware/Edge_Deployment_Guide/b_HyperFlex_Edge_Deployment_Guide_4_0/b_HyperFlex_Edge_Deployment_Guide_4_0_chapter_01000.html#topic_55FADDE9E15C4B1CB7FF977F28AAF09B
Cisco HyperFlex Edge 2-Node clusters requires the use of Cisco Intersight for initial deployment and ongoing operations using the invisible cloud witness. HyperFlex Edge 2-Node clusters cannot be deployed using the on-premises installer.
Kirk...
Hi ,
thank you for reply, If i register hyperflex node my intersight id and if i want to move hyper flex to another intersight id.
is it possible to move to another id?
