Community Helping Community
1602
Highlighted
Beginner
UC on UCS with iSCSI
I was wondering if there is any update regarding UC on UCS support for booting from iSCSI SAN?
I would like to implement the follwoing scenario: B-Series Chassis with an ESX 5.1 B200M3 Server which hosts UC Apps (UCSM 2.1).
Could we boot that server from iSCSI SAN (network running 10Gb, no-drop QoS policy for boot vNICs)?
According to the link below, only FC SAN is supported, is that still correct? Is this feature enhancement on the roadmap?
http://docwiki.cisco.com/wiki/UC_Virtualization_Supported_Hardware#Storage
Thanks!
Dmitri
1 ACCEPTED SOLUTION
Re: UC on UCS with iSCSI
Hello Dmitri,
Yes, iSCSI SAN is termed as specs based support.
Padma
6 REPLIES 6
Hello Dmitri,
I believe you are referring to ESXi hosts accessing datastores created on iSCSI LUN where UC VMs will be stored.
It is supported under Specs based design for SAN ( FC / FcoE / iSCSI )
Storage recommendations for UC apps
http://docwiki.cisco.com/wiki/UC_Virtualization_Storage_System_Design_Requirements#General_Guidelines_for_SAN.2FNAS
Padma
Beginner
Hi Padma,
I actually mean booting that ESXi host from an iSCSI LUN as well. I appreciate your help.
Dmitri
Hello Dmitri,
UCS servers supports iSCSI boot for ESXi.
Please check here for minimum HW / SW requirements
https://supportforums.cisco.com/docs/DOC-18756
HCL - HW / SW / FW Matrix
http://www.cisco.com/en/US/products/ps10477/prod_technical_reference_list.html
UCSM config guide
http://www.cisco.com/en/US/products/ps10281/products_installation_and_configuration_guides_list.html
Padma
Beginner
Hi Padma,
Yes, I'm aware of that. But the question is - is boot from iSCSI LUN supported for UC on UCS deployments?
Can I boot a B200 Server from iSCSI LUN and run Call Manager on top of that?
I heard about certain restrictions and a limited TAC support if not following the design guidelines and was wondering if this scenario is supported (or coming in the future).
Dmitri
Hello Dmitri,
Padma
Beginner
That's great, thank you!
Content for Community-Ad
FusionCharts will render here
