UC on UCS with iSCSI
dfedotovs
I was wondering if there is any update regarding UC on UCS support for booting from iSCSI SAN?
I would like to implement the follwoing scenario: B-Series Chassis with an ESX 5.1 B200M3 Server which hosts UC Apps (UCSM 2.1).
Could we boot that server from iSCSI SAN (network running 10Gb, no-drop QoS policy for boot vNICs)?
According to the link below, only FC SAN is supported, is that still correct? Is this feature enhancement on the roadmap?
http://docwiki.cisco.com/wiki/UC_Virtualization_Supported_Hardware#Storage
Thanks!
Dmitri
Hello Dmitri,
Yes, iSCSI SAN is termed as specs based support.
Padma
6 Replies 6
padramas
Hello Dmitri,
I believe you are referring to ESXi hosts accessing datastores created on iSCSI LUN where UC VMs will be stored.
It is supported under Specs based design for SAN ( FC / FcoE / iSCSI )
Storage recommendations for UC apps
http://docwiki.cisco.com/wiki/UC_Virtualization_Storage_System_Design_Requirements#General_Guidelines_for_SAN.2FNAS
Padma
Hi Padma,
I actually mean booting that ESXi host from an iSCSI LUN as well. I appreciate your help.
Dmitri
Hello Dmitri,
UCS servers supports iSCSI boot for ESXi.
Please check here for minimum HW / SW requirements
https://supportforums.cisco.com/docs/DOC-18756
HCL - HW / SW / FW Matrix
http://www.cisco.com/en/US/products/ps10477/prod_technical_reference_list.html
UCSM config guide
http://www.cisco.com/en/US/products/ps10281/products_installation_and_configuration_guides_list.html
Padma
Hi Padma,
Yes, I'm aware of that. But the question is - is boot from iSCSI LUN supported for UC on UCS deployments?
Can I boot a B200 Server from iSCSI LUN and run Call Manager on top of that?
I heard about certain restrictions and a limited TAC support if not following the design guidelines and was wondering if this scenario is supported (or coming in the future).
Dmitri
Hello Dmitri,
Padma
That's great, thank you!
