11-20-2012 06:43 AM - edited 03-01-2019 10:43 AM
Greetings All,
Just a heads up that the latest major version of UCSM has been released.
Release Note:
https://www.cisco.com/en/US/docs/unified_computing/ucs/release/notes/UCS_28313.html
New Features Include:
If you have any questions or comments, let us know.
Robert
11-22-2012 01:05 AM
Hi Robert,
Thanks for updating with latest releas of UCS 2.1(1a) firmware
I wanted to understand how PV Count Optimization (VLAN Compression. Only available on 6248/6296 Fabric Interconnect) works in 6248 and 6269
-Amit
11-22-2012 06:49 AM
Amit,
I'll give you the long answer so you understand the relevance of the feature. In UCSM each Fabric Interconnect has a Port-VLAN count limiation. The Port VLAN count is a total of each & every VLAN allowed on each vNIC in the system, plus the # of VLANs allowed on each border interface (uplink). These have been slowly increased across versions from 3000 -> 6000 -> 14000 -> 32000 now in version UCSM 2.1 (with VLAN compression disabled)
You can see what your VLAN port limit is with
UCS-6296-A# scope fabric-interconnect a
UCS-6296-A /fabric-interconnect # show vlan-port-count
VLAN-Port Count:
VLAN-Port Limit Access VLAN-Port Count Border VLAN-Port Count Alloc Status
32000 18 20 Available
[After enabling VLAN compression]
VLAN-Port Count:
64000 18 20 Available
As you can see just by enabling VLAN Compression, my PV count greatly increases. In my lab example above I have barely anything configured, so let's take a real world example . Let's say your UCSM domain looks something like this:
VLANs created: 100
VLANs allowed on each vNIC: 100
vNICs per Service Profile: 2
Service Profiles: 50
Uplink (Border) Interfaces per FI: 2 (Non port-channeled)
The PV count would be calculated as:
(100 VLANS * 4 vNICs per Service Proflie * 50 Service Profiles) + (100 VLANs * 2 Uplink Interfaces)
= 20200
And you can see, if you had more VLANs, vNICs, or service profiles, the count woudl increase accordingly. This is why its best practice to only allow VLANs the service profile host needs. The customers that hit this limiation are usually multi-tenant cloud providers where they need to allow all VLANs on all hypervisor vNICs to allow their tenants VM resources to be migrated to any host. Another case where this limitation can be hit is with the Nexus 1000v, where the VLAN provisioning occurs at the N1K level and all VLANs need to be passed soutbound from UCSM to the N1K.
So why does this matter? Well the higher the vlan port count the more processing strain it puts on the system managing all the internal counts & VLAN states. With this new feature UCSM will automatically map the state of multiple VLANs into a single state or "group" which greatly reduces the CPU load on the system and allows us to safely increase the overall PV count.
To enable this feature simply go to the "LAN" tab in UCSM, click on "LAN Cloud" on the left navigation pane, click on the "Global Policies" tab on the right pane and you'll see a radio button for "VLAN Port Count Optimization" Enabled/Disabled. Once enabled - that's it! UCSM will to all the magic of creating the VLAN groups transparently within the system and optimize the PV count for you.
**Since this is a new feature, it will be disabled by default for both upgrades and new installs. In future releases this default may be changed.
Hope this helps! - Let me know if you have any questions.
Robert
11-22-2012 11:20 PM
Thanks Robert for your detailed explanation, however I have few more question for you
VLANs created: 100
(100 VLANS * 4 vNICs per Service Profile * 50 Service Profiles) + (100 VLANs * 2 Uplink Interfaces) = 20200
VLAN created: 500
VLAN allowed on each vNIC: 500
vNICs per Service Profile: 8
Uplink (Border) Interface per FI: 2
500 VLANs * 8 vNICs per Service Profile * 50 Service Profiles+ 500 VLANs * 2 Uplink = 201000
What will happen in this scenario ?
Looking forward for your reply
-Amit
11-23-2012 01:32 PM
Answers inline.
Let me know if you have further questions.
Robert
VLANs created: 100
[Robert] Just a typo. The forumula is correct, the value for "2" vNICs per Proifle above should be "4".
VLAN created: 500
[Robert] First, the system would not allow you to deploy that many profiles due to the PV limit. As soon as you reach the limiation the system would throw a configuration error alert. From a design perspective, the reason most customers use more than two vNICs per host is for operational granularity. They'd like to treat each vNIC different, perhaps apply different levels of QoS, adapter policies etc. In hypervisor environments you might use 1 vNIC for vMotion, maybe one for Management. In this case each of these vNICs only need to allow their single VLAN. You likely wouldn't need all 500 VLANs being allowed on all eight vNICs. If you prune off uncessary VLANs you can easily drop below the 64000 limitation. This is where best-practice design comes in.
-Amit
11-27-2012 06:33 AM
Thanks for your reply Robert
We are also one of the cloud providers and we are facing this issue.
I would like to know how I can expand UCS Domain and how it will help us to get ride of VLAN limitation? you can provide me a link where I can refer how to expand UCS Domain and use UCS Central
Also would like to know what is the best practice you would follow to designe a public cloud (you just give me a overview if you cann't comment here)
-Amit
11-27-2012 07:36 AM
Amit,
Cisco Validated Design ( CVD ) docs are good reference while designing solutions.
VMDC guide is here
http://www.cisco.com/en/US/solutions/ns340/ns414/ns742/ns743/ns1050/landing_vmdc.html
Datacenter Design guides
http://www.cisco.com/en/US/netsol/ns743/networking_solutions_program_home.html
Padma
