UCS 2.12a iSCSI error for named-policy-unresolved
DAVE GENTON
Level 2
Level 2
UCS iSCSI error 2.1.2a upgrade from 2.1(1e)
Error Code and Fault information, authNAMEprofile not resolved
ID 347227
cause:named-policy-unresolved
code:F4529533
  Search comes up nil on this fault code and error id and cannot find link in UCSM to fix error from occurring, any ideas ??    Path shows each blade/vnic/boot nic
Dave
5 Replies 5
DAVE GENTON
Level 2
Level 2
Still found nothing but wanted to add after doing upgrade full path shows sub-org they are in and then server/blade/ and
/iscsi-boot-params/boot-vnic.  They are not using any isci authorization profiles.
Padma I do not have access to that bug report as its elevated in level apparently.  Can you send me any info I can pass on to customer ??    Looking for workaround, fixed in, etc.   Want to explain but I myself have only that its cosmetic, will they stay until fix or something to edit so its resolving to remove errors ??
thanks
dave
Hi Dave,
You should have access to this bug as it is external, please try the website below and copy the bug ID CSCui43905
http://tools.cisco.com/Support/BugToolKit/action.do?hdnAction=searchBugs
If this doesn't work you can go to www.cisco.com and search for the following "
"Software Bug Toolkit bugs ddts"  it should be the first hit
I'm getting this error under 2.1(3a), seems the bug hasn't been fixed from 2.1(2a).
Workaround:
Create a iSCSI Authentication Profile named "default".
Todd
