438
Highlighted
Beginner
UCS 5108 AC2 Chassi and B200 m3/m4 blades firmware update
Hi Guys,
I'm new to the UCS but need to investigate upgrade to the 3.2.3 from 2.2.6C for 2 reasons
Upgrade to VMware esxi 6.5 and CPU security patches.
Does direct upgrade from 2.2.6C to 3.2.3 supported and recommended or there is another better way?
1 ACCEPTED SOLUTION
Re: UCS 5108 AC2 Chassi and B200 m3/m4 blades firmware update
An upgrade from 2.2.6 to 3.2 is going to require a few steps.
First you will need to make sure you do not have any deprecated hardware for the 3.X release. Then you will need to upgrade from 2.2.6 to 2.2.8 to 3.2. You may also choose to go from 2.2.6 to 3.1 to 3.2. Since there are major changes from 2.2.6 to 3.2, we require a multi-step upgrade.
More info in the 3.2 Release notes - https://www.cisco.com/c/en/us/td/docs/unified_computing/ucs/release/notes/CiscoUCSManager-RN-3-2.html
2 REPLIES 2
Beginner
Thanks Wesley!
I wonder if Spectre/Meltdown firmware upgrade will be released for the 2.2.8? Its old firmware but sounds like an update to the 2.2.8 is safer comparing to big jump to 3.1!
Content for Community-Ad
August's Community Spotlight Awards
